No, it's with the flipped axle.
EdAbbey
City: Tacoma
Post by EdAbbey »
66patrick wrote:No, it's with the flipped axle.
Is there a thread somewhere that explains how to do the axle flip? thx
No, how to UNDO the flip.
axle flip is a bad idea.....dropped axle is the way to go or take out some springs(which can cause other issues)
It is wiser to "drop", than to "flip".... :joker
Do a search as there are plenty of threads on this topic.
71superbee
City: lake anna
State: VA
Post by 71superbee »
my 70 d100 survivor..
That is a RAD truck man. :Thumbsup I dig the stance.
Very nice truck.
vroc4507
City: Sanborn
State: IA
Post by vroc4507 »
facechicken wrote:axle flip is a bad idea.....dropped axle is the way to go or take out some springs(which can cause other issues)
I have read a few posts on the axle flip and it definitely seems to be a lot less costly than a dropped axle. Can you explain further on why the flip is a bad idea?
Thanks, BK
Campinfool
City: Wisconsin Rapids
State: WI
Post by Campinfool »
Very nice!!
Joel
Oldguy
City: Reno
Post by Oldguy »
BK, flipped axles in the front can cause bump steer. That is really bad since you can not steer the vehicle when you hit a bump just right. Very scary if you've ever had it happen to you! Hope this helps. Mike
vroc4507
City: Sanborn
State: IA
Post by vroc4507 »
Oldguy wrote:BK, flipped axles in the front can cause bump steer. That is really bad since you can not steer the vehicle when you hit a bump just right. Very scary if you've ever had it happen to you! Hope this helps. Mike
Thanks man, appreciate the heads up! I figured there was a good reason just had to know. :thinking Also my apologies for highjacking the thread, I just had to ask.
Oldguy
City: Reno
Post by Oldguy »
Not a problem. You won't know if you don't ask. Mike
behindthebadge
City: Ozark
State: AR
Post by behindthebadge »
1967 D100 short sweptline bed, custom cab, 318 v8.
behindthebadge
City: Ozark
State: AR
Very Nice!
I can almost see Don Knotts driving it.
Campinfool
State: WI
That is nice!! :Thumbsup
Joel
behindthebadge
City: Ozark
State: AR
jimmy wrote:Very Nice!
Nip it... Nip it in the bud!
JimE
City: Glendale,
Post by JimE »
70 Camper Special with a 383, automatic, PS, PB, air conditioning with a 3.54 sure grip. I moved the fuel tank out of the cab and installed a 33 gal. bronco tank between tho rails, i also went with Scarebird front disc brakes. Jim
rickharrold
City: blackwell
Post by rickharrold »
Jim, that is nice, I may have it's brother in the color of blue.
