8 bolt disk brakes
- City: breaux bridge
- State: LA
8 bolt disk brakes
i was at the pull a part today and was looking at a 86 ford 3/4 ton with some kind og link pin front end with disk brakes. has anyone tried to use the spindels off the ford on say a d200? looks like it might be a cheap way to put 8 lug disk brakes on , what you think? am i not seeing to whole picture?
tks james
tks james
1962 D-200 custom cab,318 poly auto
1966 d-100 318 LA motor header,cam carb,727 over drive 4 wheel disk brakes 18" wheels rat rod looking
1947 international K3
BMW Z3 with 347 SB ford & T5 stuffed in it.
2 HD's & a 1984 900 ninja
Re: 8 bolt disk brakes
This might be the twin "I" beam front. I don'tlostbug wrote:i was at the pull a part today and was looking at a 86 ford 3/4 ton with some kind og link pin front end with disk brakes.
recall anyone mentioning this as a candidate
for front end parts.
a second look.... eh?
- Hippy_Dave
- City: Union
- State: WI
Keep us posted !!! I was doing research a while back on front disc swap, but got busy with life and had to shelf it. Come springtime I'll probly get back to it? AT any rate it seems no-one wants to share what works for 3/4 ton disc swap unless they bought it in akit. It would be REALLY nice to know if this pans out for you
69 D-200
37 Delivery Sedan (in pieces)
92 Dakota - traded for a 2001 Ram 1500
79 Dodge Aspen 2-dr -- didnt have time for it
2010 Charger former squad car = Love it
sweeet
sweeet
Steven has disc brakes on the front of his D200. Search for his posts. I know he made his own brackets.
I'd like to see if this Ford setup works too.
- State: LA
still working on the front end but found a web sight that has kits for the rear dana 60 might take a look see www.greatlakeoffroad.com wist someone made a kit for the fronts
james
james
http://sweptline.org/forums/viewtopic.php?f=32&t=25766lostbug wrote:still working on the front end but found a web sight that has kits for the rear dana 60 might take a look see http://www.greatlakeoffroad.com wist someone made a kit for the fronts
james
Just ordered front discs for my 67 W200. Pull a big boat so i gotta stop!lostbug wrote:still working on the front end but found a web sight that has kits for the rear dana 60 might take a look see http://www.greatlakeoffroad.com wist someone made a kit for the fronts
james
http://www.blackbirdscustomtrucks.com/
John Kelly
It's been a while since I looked into the same thing and if my memory serves me right, you could use the Ford spindles. You would have to have the axle bent to obtain the correct camber and use a spacer between the spindle and axle. Also, I think the kingpin diameters are slightly different so you would have to machine either part.
For my 68, I used Chevy rotors because their width was narrow enough for the Dodge spindle length. Then I bolted a 1/4" round plate to the spindle which is used to mount a Dodge caliper. I've attached the only picture I have right now. Let me know if you need more information and I will be happy to help.
- Attachments
- IMG_0181_1.jpg (26.58 KiB) Viewed 3512 times
Dan
68 D-200 Camper Special, 383/727
71 D-300, 440/727
72 Luxury LeMans, 455-TH400
80 MGB roadster, 1800/4sp w/OD
49 Pontiac Stream Liner, 2-door Torpedo back, I-8, 3 on the tree
1974 MGB-GT
71 D-300, 440/727
1974 MGB-GT
- dakotadave
- City: west fargo
- State: ND
holy hell, finally! i cant believe this isnt getting more attention really, frankly i'd like to know a lot more about it, like about turning the hubs and what year calipers/rotors work.soopernaut wrote: http://sweptline.org/forums/viewtopic.php?f=32&t=25766
if i had power disc brakes (and power steering somehow, someday) on my truck i might start driving it again.
I would email sales@scarebird(dot)comdakotadave wrote:holy hell, finally! i cant believe this isnt getting more attention really, frankly i'd like to know a lot more about it, like about turning the hubs and what year calipers/rotors work.soopernaut wrote: http://sweptline.org/forums/viewtopic.php?f=32&t=25766
- City: 08046
- State: NJ
I just emailed scarebird to his ebay account, he said he does not have brake conversion for 8 lugs..I did some research and found a webiste where a guy took all the parts from a 3/4 ton chevy front axle to do the conversion. http://www.offroadexchange.com/diskbrakeswap.htm
I would like to write up a tech article about my 68 D-200 Camper Special disc brake conversion, but I just don't have any spare time right now.
Here is my parts list:
-1985 Chevy rotors (Dodge and Ford rotors are too wide for our spindle length).
-Custom bearing spacers to adapt the Dodge bearings in the Chevy rotor (if I were to do it again, I'd use the Chevy bearings and make sleeves for the spindle).
-1/4" thick round plate, OD slightly smaller than the ID on the rotor backside, see picture from previous post (around 9"-10"). The ID is a slight press fit on our Dodge spindle. Then transfer punch marks on the plate using the four holes in the spindle as a guide and bolt together using grade-8 fine thread bolts and red loctite.
-1977 Dodge 3/4 ton calipers bolt to the aformentioned 1/4" plate using spacers to center it over the rotor.
-Brake hoses same as calipers.
-One-piece threaded shaft collar (I think 9/16"-18, verify first) inplace of factory nut, keeper and cotter pin.
-Grease seal I don't have the number right now (give the OD, ID and thickness to any bearing supplier and they should be able to help you).
Hope this helps.
Hope this helps.
Dan
71 D-300, 440/727
1974 MGB-GT
71 D-300, 440/727
1974 MGB-GT
Really ,then why was he selling it? Selling a product you don't have sounds like fraud to me.CXCRAZINESXS wrote:I just emailed scarebird to his ebay account, he said he does not have brake conversion for 8 lugs...
- demulsion
- City: Bremerton
soopernaut wrote:Really ,then why was he selling it? Selling a product you don't have sounds like fraud to me.CXCRAZINESXS wrote:I just emailed scarebird to his ebay account, he said he does not have brake conversion for 8 lugs...
Either that, or he hasn't got the foggiest that on Dodges 3/4 ton = 8 lug. Just my guess.
demulsion wrote:soopernaut wrote:Really ,then why was he selling it? Selling a product you don't have sounds like fraud to me.CXCRAZINESXS wrote:I just emailed scarebird to his ebay account, he said he does not have brake conversion for 8 lugs...
Well it says D250 calipers and rotors are used. Something just doesn't add up.We now offer a simple disc conversion for your classic Dodge 1957-71 3/4 ton 2WD truck. This uses D250 rotors and calipers with our bracket; you will machine the outer edge of your existing drum hubs, and replace the studs. Brackets are zinc plated when available, plain steel if not. Auction is for both sides, and for the brackets and banjo bolts only.
- City: Parker
Just got an email back from Scarebird and they sent me the instructions on the D200 install. The brackets are part (SNW) $185.
Sorry about the formatting.
1958-71 Dodge 3/4 ton Pickup w/2800lb axle Front Disc brake conversion
1. Crack front wheel nuts loose, chock up rear wheels. Jack up front end of car, support outer control arms with jackstands. Remove front wheels, drum/hub assembly. Put a few drops of penetrant oil, such as AeroKroil on brakeline nuts where they screw into rubber lines.
2. Take drum/hub assembly and remove drum by using a swedge cutter on the base of the studs, then pressing out and discard studs. Clean off wheel surface and register with wire wheel or beadblaster. Machine outer edge of hub flange to fit inside rotor with about 0.010” loose fit. This is important, as it is what centers the rotor on the hub. Replace studs with ¼” longer or more studs. Mopar used several different suppliers for the drums, and they had 3 different sized studs. Dorman 610-103 is one. Best approach is to use an ARP or Moser stud and cut down to length. We used Raybestos #6249B or NAPA 641-3115.
3. Disconnect brake flexible line at frame by unscrewing hardline nut with flare wrench, then removing nut. Undo and remove drum retaining bolts. Remove drum backing plate, hose and all drum hardware in one assembly. Clean off spindle assembly well.
4. Place adapter plate over spindle with caliper bolt retaining nut welds facing inward, and caliper opening to the rear. Make sure no dirt is lodged between spindle and plate.
5. Verify that rotor lays flat against hub by fitting rotor backwards onto hub. If the stud knurls interfere with rotor, countersink stud holes in rotor to clear knurls.
6. Clean and repack wheel bearings. Install new seal. Assemble hub onto spindle, tighten outer nut to spec, then secure with keeper, new cotter pin and dustcap.
7. Place rotor onto hub, and run two or three lugnuts down finger tight to retain rotor. Wipe down rotor with alcohol, lacquer thinner or other cleaner.
8. Wash hands! Rotor must be squeaky clean.
9. Slide assembly into caliper bracket. Make sure bleed nipple faces up. We recommend buying loaded calipers, but if buying pads separately use caliper application below. Tighten caliper bolts to 35 foot-pounds. Check fitment and rotate rotor to check clearance. Install flex lines.
10. Master cylinder and proportioning valve specs are quite varied. I would recommend 1972 D/W 200 or similar disc master cylinder for best performance match available in both power and manual flavors. Plumb in an adjustable proportion valve in the line going to the rear cylinders, or use a disc proportioning valve if rears suffer from excessive lockup in panic stops.
11. Bench bleed disc master cylinder. Mount MC on car, then gravity bleed entire system first to eliminate most of the air, then pump bleed and test, otherwise your distribution block may jam from a pressure imbalance.
12. Replace wheels, install lug nuts, lower car and torque nuts to spec. Test drive carefully- no hard stops, a series of 30 smooth stops from 30 mph, with a 30 second cooling period between stops will bed in the pads properly. Let cool for an hour after finished bedding.
Part Application NAPA Raybestos
Rotor 1989-93 Dodge D250 diesel 2WD front 86025 70625(RGS)
Caliper, LH 1994-98 Dodge D250 w/7500 GVW axle 242-2140 FRC4414
Caliper, RH 1994-98 Dodge D250 w/7500 GVW axle 242-2141 FRC4413
Brake Hose LH 1979-82 Chevy G10 Van 36855 BH36855
Brake Hose RH 1979-82 Chevy G10 Van 36956 BH36956
Banjo Bolt 1994-98 Dodge D250 w/7500 GVW 82703 DORMAN Part # 13940
Scarebird Classic Brakes LLC warrantees our product for 90 days after purchase against manufacturing defects. Scarebird Classic Brakes LLC is not responsible and held harmless for errors due to faulty installation or use of non-specified/inferior components or adaptation to non-OEM applications. Scarebird Classic Brakes LLC reserves the right to change/delete components/applications without notice. Please do not hesitate to email us for latest specifications or technical inquiries. Contact: sales@scarebird.com Thank you.
- Dood
- City: Shoreline
Maybe I just haven't seen the right posts, but has anyone done the 8 bolt conversion yet?
- City: Parker
lol...not yet. Have to save my allowance for weeks for the Scarebird brackets at $185.Dood wrote:Maybe I just haven't seen the right posts, but has anyone done the 8 bolt conversion yet?
- Dood
- City: Shoreline
Ha! OK, I'm thinking very hard about doing this but I'm hoping someone else with a digital camera will blaze the trail.
- Dood
- City: Shoreline
I've been doing some investigation... Here is my parts list so far with a correction to the caliper application. Corrections, comments, etc. are encouraged and welcomed.
Code: Select all
Part #req Application Mfr. Part# Notes
Rotor 2 1989-93 Dodge D250 diesel 2WD front Raybestos 70625R $52 from Amazon
Caliper, LH 1 1994-98 Dodge D2500 w/7500 GVW axle Raybestos FRC4414 RC fully loaded ($64 RockAuto), FRC Amazon $40
Caliper, RH 1 1994-98 Dodge D2500 w/7500 GVW axle Raybestos FRC4413 RC fully loaded ($64 RockAuto), FRC Amazon $8!!!!
Brake Hose LH 1 1979-82 Chevy G10 Van Raybestos BH36855
Brake Hose RH 1 1979-82 Chevy G10 Van Raybestos BH36956
Banjo Bolt ? 1994-98 Dodge D2500 w/7500 GVW Dorman 13940
Studs 16 Moser
