Horn Location
homeboymi
Horn Location
Post by homeboymi »
I have two inexpensive horns on my 1968 Dodge D100. They are red plastic like the ones at Harbor Freight. I now have an original horn but don't know the location under the hood for it. Could anyone tell me where this horn is bolted on my truck?
powerwagon54
City: Washougal
Re: Horn Location
Post by powerwagon54 »
right side of core support between radiator and right fender
Wildergarten
City: Los Gatos
Re: Horn Location
Post by Wildergarten »
homeboymi wrote:
Sun Mar 08, 2020 5:21 pm
I've seen both single and double factory horns in a few places, each with special hangar brackets to fit:
  1. One on each side hanging off the sides of the angle-iron shock supports,
  2. Two top and bottom on passenger's side of the radiator inside the front panel,
  3. Outside the front panel on one or both sides of the radiator.
So you'll have to look at the horn mounting brackt and the sheet metal in the engine compartment for clues. If you see a 3/8-NC rectangular nut welded to the front panel with an adjacent 1/4" hole for the tab on the bracket, that's likely the spot(s).
WarEagle
City: Huntsville
Re: Horn Location
Post by WarEagle »
My '67 D100 factory double horns are mounted off the passenger side angle iron shock support with one fastener and nut that passes thru each of the horn brackets.
Re: Horn Location
That is absolutely NOT a factory location, nor wiring. Easy to tell simply by observing the blue crimps on the spade connectors - that is NOT a factory terminal.
Wildergarten
City: Los Gatos
Re: Horn Location
PwrWgnDrvr wrote:
Mon Sep 28, 2020 9:21 am
My '67 had the exact same setup with the horns on the shock brackes, sans crimps.
WarEagle
City: Huntsville
Re: Horn Location
Post by WarEagle »
PwrWgnDrvr, then for all of us novice forum members where exactly is the factory mounting location? Just curious, as I might want to relocate my dual horns to that location in order to be as original as possible. Thanks.
Re: Horn Location
Inside of core support, passenger side or hanging off the hood near the cowl.
Just looked thru a couple hundred of my pics of junkyard sweptlines and didn't find a one with the horns in that position.
Wildergarten
City: Los Gatos
Re: Horn Location
PwrWgnDrvr wrote:
Mon Sep 28, 2020 11:29 am
The factory angles with the horns are longer than usual (I have a pair). The horns themselves are different too in that the mounting bracket is parallel to the face of the angle iron shock support. If you'd like photos, I can do that.
quickgraffix
City: stockton
Re: Horn Location
Post by quickgraffix »
this reminds me i need to go through my wiring my horn doesn't work either
Re: Horn Location
mine have all been on the hood, drivers side. 66 is the latest i've owned
Wildergarten
City: Los Gatos
Re: Horn Location
quickgraffix wrote:
Tue Sep 29, 2020 1:26 pm
Pro tip: Check the relay before looking at anything else. Then tie the horn directly to the battery and see if it actually works.
Re: Horn Location
Trucks in my yard.
70 D500. Horns with relay to right of radiator on backside of radiator support between Rad and inner fender.
1968 Fargo. Horns with relay to right of radiator on backside of radiator support between Rad and inner fender.
1968 Dodge. Horns with relay to right of radiator on backside of radiator support between Rad and inner fender.
1967 D300. Dual Horns with relay to right of radiator on backside of radiator support between Rad and inner fender.
1966 W200. Had dual horns on hood rear support with relay on drivers side under hood
1966D100. Had a single horn on hood rear support with relay on drivers side under hood. Evidence it did have a second horn at one time.
I have also removed dual horns with wiring harness from the hood of a 66 D series that are put away for my 66 W100.
