Info: 1970 D200 Camper Special regular cab. 318/3speed auto
First, I have a cut "RED" wire in a wiring harness. This harness is the set of wires running from the connection block located next to the brake booster on the firewall. The wiring then runs down the driver side fender, and the other "cut" end protrudes out of the wire wrapping. These are the 2 photos below. This wiring harness continues on to the front lights of the truck, running just up to the driver side of the radiator. I do not see any cut connections anywhere else on the block connectors on the firewall that this may have been part of.
Next, there is a "BLACK" wire cut which is part of the ballast resistor wiring harness. After tracking down this section, I have found the other end of this wire is running to the alternator, but it is simply twisted around a long threaded fastener on the top side of the alternator. There is also a larger gauge "Black" wire running off the ALT, but this wire runs directly through the firewall and I have traced it to the back side of the dash cluster. This is not what is shown in MrMopar's wiring images, so maybe there is some variations to the production dates and/or it's just changes unknown in the records.
The last thing I could do is really look over all 3 of the block connectors on the firewall, checking them against the wiring diagrams. To note, I do not have any issues that I've noticed so far. That is, all my lights work, and the relay I've added under the hood is all new for my fog lamps.
As a quick reference, here are the links to the wiring diagrams that have been really helpful!
viewtopic.php?t=27800
