Driveshaft length w/numbers please
Jesuschrystler
City: Durant/OKLA
Post by Jesuschrystler »
I swapped a '87 318/904 into my '70 LWB. I need the correct driveshaft length. Regular (not long) tailshaft. I measured 68" from shaft end to shaft end (not yoke), but I might have been generous. I'm finding later model truck driveshafts LWB with 66" ones, will that length work? I will need the correct yoke I know but is the 66" too short? Need some more info before I buy. I don't have the $$$ to get one made either.
Re: Driveshaft length w/numbers please
Jesuschrystler wrote:I swapped a '87 318/904 into my '70 LWB. I need the correct driveshaft length. Regular (not long) tailshaft.
I believe the stock LoadFlite trannys in Sweptlines were all the long tail shaft style.... so you may
encounter difficulties locating a bolt in shaft. :thinking You might want to check with a local
drive shaft specialist to see if you're getting into an excessively long one piece shaft. You
might need to have a two shaft drive line with a carrier bearing. :thinking :2cents I'm sure
others can chime in on this too.
Jesuschrystler
City: Durant/OKLA
I know there's a factory driveshaft for this engine/trans combo. I had a few inches cut off when I put in the slant 6/904 combo. I need a driveshaft for a small block 318 w/Auto trans. Cmon I know with 57 views SOMEONE knows what I'm talking about. Any parts guys out there...???
Post in parts wanted instead.
Jesuschrystler wrote:I know there's a factory driveshaft for this engine/trans combo.
There isn't one for the truck it is in now, since that transmission was never put in a Sweptline truck from the factory. Where is the driveshaft from the vehicle you got the engine/transmission from? If it was a long bed regular cab truck you could probably have that one shortened. I believe it costs less to have that done that to buy a new one.
