LA 318 Motor Mounts...anyone have pics?
- Jesuschrystler
- City: Durant/OKLA
Does any one have any info/pics on this. I'm swapping my Slant Six for a 1987 318 w/727 trans. I see pics listed but they've been taken down by whoever hosted them. I need to know what will work off the Slant Six etc.... Also, I have a 1987 shortbed Ram that has power steering and I want to know if the steering box will fit on a '70 ? Thanks!
Re: LA 318 Motor Mounts...anyone have pics?
Jesuschrystler wrote:Does any one have any info/pics on this. I'm swapping my Slant Six for a 1987 318 w/727 trans. I see pics listed but they've been taken down by whoever hosted them. I need to know what will work off the Slant Six etc.... Also, I have a 1987 shortbed Ram that has power steering and I want to know if the steering box will fit on a '70 ? Thanks!
Just the rubber isolaters from between the frame mount and block mount will work for the 318.
Steering box from 87 will not work without major fabbing and fabrication.
- Jesuschrystler
- City: Durant/OKLA
Thanks dodgeboykin!
You might be able to see the right side engine mount bracket
in this pic. As Kim points out, the insulators from your Slant 6
can be used with the LA318.
- Roxyflash
- City: East Moline
- State: IL
I have a set for sale if you need a picture of them I can take one
- Jesuschrystler
- City: Durant/OKLA
Is this for the LA block too? I see you have the Poly motor pic.
They're the same.Jesuschrystler wrote:Is this for the LA block too? I see you have the Poly motor pic.
- Jesuschrystler
- City: Durant/OKLA
Hobcobble, do you have any pics of the drivers side? I'm running into problems with the motor wanting to sit sideways. Anyone have any ideas? I know one is off from the other.
Jesuschrystler wrote:Hobcobble, do you have any pics of the drivers side? I'm running into problems with the motor wanting to sit sideways. Anyone have any ideas? I know one is off from the other.
Is it bolted to block tabs/mounts correctly.
viewtopic.php?f=5&t=38106Jesuschrystler wrote:Hobcobble, do you have any pics of the drivers side? I'm running into problems with the motor wanting to sit sideways. Anyone have any ideas? I know one is off from the other.
Look at the large photo....
