magnumcid
Posts: 110 Joined: Tue Dec 15, 2009 4:39 pm
City: Sherbrooke
Post
by magnumcid » Sat Dec 04, 2010 1:50 pm
So I was browsing some classifieds when I came across an 8.0 L V10 for sale out of a '96 Ram... Does anyone know what manual transmissions will fit this? The donor truck is an automatic
. Any chance my 435 4 speed will bolt right up?
Has anyone ever put a V10 in a swepty before?
***I just realised I spelt transmission wrong
1967 Fargo Power Wagon 200; Poly 318/NP435/201/4.10s PROJECT
1996 Chebby S10 ZR2; 4.3 Vortec/5 Spd./Manual 4x4 OFF-ROAD BEATER
2003 Chebby Cavalier; 2.2 Ecotec/Auto DAILY BEATER
digdoug
Posts: 2864 Joined: Wed Dec 31, 1969 6:00 pm
Post
by digdoug » Sun Dec 05, 2010 1:00 am
They used the same NV 4500 as the cummins trucks.
garrett
Posts: 127 Joined: Fri Jul 17, 2009 4:35 pm
City: Morgan
State: UT
Post
by garrett » Thu Jan 06, 2011 7:49 pm
Digdug has it the v-10 and diesel share the same bellhousing. Would take a few adjustments.
The one that runs 71 d-100 sb 440,727 3.91spool
Half parted out 71 d-100 sb
70 d-100 lb adventurer maybe 12valve diesel drag truck ?
OH YEAH finally a 69 crewcab d-200 uteline
DavidWymore
Posts: 1016 Joined: Wed Dec 31, 1969 6:00 pm
City: El Centro (of nowhere)
Post
by DavidWymore » Fri Jun 28, 2013 7:20 pm
So, anyone ever do it?
gyman98
Posts: 432 Joined: Tue Jan 11, 2011 4:25 pm
City: Saskatchewan
Post
by gyman98 » Fri Jun 28, 2013 11:00 pm
The nv4500 Is different from the diesels. The input shaft is smaller
DavidWymore
Post
by DavidWymore » Sat Jun 29, 2013 12:39 am
The V8 version input shaft is smaller. Cummins and V10 are the same.
I wonder about the 10 fitting under the good and between the frame and fenders.
DavidWymore on Sat Jun 29, 2013 10:24 am, edited 1 time in total.
gyman98
City: Saskatchewan
Post
by gyman98 » Sat Jun 29, 2013 7:51 am
The V8 version isn't compatible. The v10 version is but just with a smaller input shaft. Not a issue unless its a high power application
Duh
Posts: 165 Joined: Sun Dec 16, 2012 9:06 am
City: Colo Spgs
Post
by Duh » Sat Jun 29, 2013 8:18 pm
David
Think of the V-10's width and depth as the A-318/ LA-318 with two extra cylinders added to the front.
The Radiator will need moved more towards the front and a Fan Shroud for the "well do I really need one" group.
For The Rear Axle The HHPP Assembly will keep some of "the hop - from hopping".
Rodger & Gabby
COS
Oldguy
Posts: 756 Joined: Wed Dec 31, 1969 6:00 pm
City: Reno
Post
by Oldguy » Sun Jun 30, 2013 2:39 pm
Had a Swepty show up at a cruise in with a Viper V-10 and 6 speed in it. Looked pretty good. Mike
DavidWymore
Post
by DavidWymore » Sun Jun 30, 2013 3:00 pm
That's awesome. Love to know more about it. Like from behind the wheel...
nytemuvr
Posts: 915 Joined: Tue Apr 10, 2012 9:49 pm
City: Rio Linda
Post
by nytemuvr » Sun Jun 30, 2013 3:12 pm
That's sweet...I've seen a Charger and a Challenger with V-10s in them. Good stuff, looks like a stock set-up.
DavidWymore
Post
by DavidWymore » Sun Jun 30, 2013 3:22 pm
I'm looking at either rebuilding the 440 for my short wide or picking up a truck V10
Posts: 8952 Joined: Wed Dec 31, 1969 6:00 pm
Post
by soopernaut » Mon Jul 01, 2013 10:46 am
Oldguy wrote: Had a Swepty show up at a cruise in with a Viper V-10 and 6 speed in it.
I never thought a Sweptline engine compartment would look small.
swept360
Posts: 50 Joined: Sun Jun 09, 2013 6:57 pm
City: Langley, BC
Post
by swept360 » Mon Jul 01, 2013 7:15 pm
soopernaut wrote: Oldguy wrote: Had a Swepty show up at a cruise in with a Viper V-10 and 6 speed in it.
nytemuvr
City: Rio Linda
Post
by nytemuvr » Tue Jul 23, 2013 1:31 am
Duh wrote: David
Rodger & Gabby
COS
Electric water pump will give you some room.
65alive
Posts: 171 Joined: Wed Dec 31, 1969 6:00 pm
City: Joseph City, AZ
Post
by 65alive » Mon Jul 29, 2013 5:52 pm
On the "bolt right up to the 435" issue, I'm almost positive a getrag bell housing from a 1st gen cummins would do the trick. I like the NV4500 better, but I do think it's possible.
