Hey guys
what does the adjustment nut on the steering box do?
where can I find a rebuild kit for the steering box?
thanks
LB
64W200 sloppy steering
Re: 64W200 sloppy steering
Check with Bud Thorp [aka PowerWagon54]. Helbman wrote:Hey guys
thanks
LB
rebuilds them. Maybe he'd have a parts kit for
you?
isn't that a pretty tough job unless you know the tricks and have the correct pullers, etc? Might be better to buy a rebuilt one (maybe I think that because I tried a few times and failed).Hobcobble wrote:Check with Bud Thorp [aka PowerWagon54]. Helbman wrote:Hey guys
thanks
LB
you?
oh, the adjustment nut can take the slack out but the worm gear is usually worn in the middle so if you make that good it can bind while the wheels are turned and it will not straighten out...at least I believe that is the case, but I have never been able to open one.
JimE wrote:Try: http://www.benchworksteering.com
I second that
