upgrading help needed
divinedragon13
City: payette
Post by divinedragon13 »
i want upgrade truck to 3.55 gears or some where around that ratio like half ton axles with disk brakes on front what will swap under front and back
currently have
truck 1970 w100
motor 472 caddy
tranny th400
transfer case np205
from a 63 3/4 front axle dana 44 or 60 believe it is a 60 with 4.11
rear 76 spincer 60 4.11 drum
master cyclinder is from a 71 power brakes
like find another set axle i can put under truck with disk up front and around 3.?? what can be swaped under the truck?
Rodger
City: COS ( Colo )
Re: upgrading help needed
Post by Rodger »
Sir
In your request of parts for your truck, remember that if you have the
front differental, you will need a front gear ratio as the rear gear ratio.
If not, you will be looking for the correct parts ... again.
Rodger & Gabby
FltSgt@msn.com
COS
daytb
City: Bucklin
Post by daytb »
might look at late 80 to 93 dodge axles they look very close on mountings
surfnuke9
City: Churchton
Post by surfnuke9 »
up to 93 will bolt in.
I put a set from a 93 W350 deisel under my W200. 3.54 gear ratio, HUGE rear brake drums and front disc brakes.
