I answered a Craigslist ad for a 90k mile 318 from a class C motorhome about 3 weeks ago. Engine fired right up, nearly 20 PSI oil pressure according to the stock electric gauge at idle. Ran slightly rough, but after working the throttle I suspect the carb might be gummed up inside a bit. Came with the 727 short tail shaft I need to go into the W200, and all the little stuff. For $350, I couldn't pass it up. Going to drop that right in the truck and be driving it soon. Also scored a Dana 70 dualie rear end for another $100, with the leaves and shocks. I'll pick that up in about a week.
Once we got it in the air and onto the stand, I noticed it has factory paint on the back of the block behind the flywheel. All the freeze plugs are original and appear in good shape from the outside. Minor leaks from valve covers are the only reason this motor is dirty outside at all really.
It's a two barrel carb and since I'm likely going GM TBI in the near future, it may not get a 4 barrel intake on it. We shall see. I also noticed the fact that it has new everything in the ignition system, including some nice heavy duty 7mm plug wires on it. Plugs are angled so I'm hoping that it has the heart shaped chambers inside, though I'm not opening it up to see.
It may get some shorty headers before it goes in, who knows. Overall, my only concern is the oil pressure. But I could always throw in a new high volume pump and reduce my worries, quite easily. Time will tell.
While I was there, the guy was telling me about the other motorhome, sitting next to the one he was parting out. Same thing with it, parting it out. It has a 50K mile 360 in it. He offered to start it for me,... that was a bad mistake. It had been a couple of weeks since it has started, based on the cobwebs on the dash by the ignition switch. Pumped the gas 4 times and hit the key. Stumbled and died. Two more pumps, hit the key, fired right off. Smooth as a Swiss watch, and 40 PSI oil pressure cold!
Immediate executive decision! My Scout 2 now gets a 318 conversion, and the W200 is getting a 360. Same price as the 318 also. Can't hardly pass that up. Momma's gonna kill me, but I have a couple of weeks to get my bed ready out in the garage.
Here's a pict, though we have all seen a 318 before I suppose
