Horn Location
Horn Location
I have two inexpensive horns on my 1968 Dodge D100. They are red plastic like the ones at Harbor Freight. I now have an original horn but don't know the location under the hood for it. Could anyone tell me where this horn is bolted on my truck?
- powerwagon54
- City: Washougal
Re: Horn Location
right side of core support between radiator and right fender
Re: Horn Location
I've seen both single and double factory horns in a few places, each with special hangar brackets to fit:
- One on each side hanging off the sides of the angle-iron shock supports,
- Two top and bottom on passenger's side of the radiator inside the front panel,
- Outside the front panel on one or both sides of the radiator.
Re: Horn Location
My '67 D100 factory double horns are mounted off the passenger side angle iron shock support with one fastener and nut that passes thru each of the horn brackets.
Re: Horn Location
That is absolutely NOT a factory location, nor wiring. Easy to tell simply by observing the blue crimps on the spade connectors - that is NOT a factory terminal.
Re: Horn Location
My '67 had the exact same setup with the horns on the shock brackes, sans crimps.PwrWgnDrvr wrote: ↑Mon Sep 28, 2020 9:21 amThat is absolutely NOT a factory location, nor wiring. Easy to tell simply by observing the blue crimps on the spade connectors - that is NOT a factory terminal.
Re: Horn Location
PwrWgnDrvr, then for all of us novice forum members where exactly is the factory mounting location? Just curious, as I might want to relocate my dual horns to that location in order to be as original as possible. Thanks.
Re: Horn Location
Inside of core support, passenger side or hanging off the hood near the cowl.
Just looked thru a couple hundred of my pics of junkyard sweptlines and didn't find a one with the horns in that position.
Re: Horn Location
The factory angles with the horns are longer than usual (I have a pair). The horns themselves are different too in that the mounting bracket is parallel to the face of the angle iron shock support. If you'd like photos, I can do that.PwrWgnDrvr wrote: ↑Mon Sep 28, 2020 11:29 amInside of core support, passenger side or hanging off the hood near the cowl.
- quickgraffix
- City: stockton
Re: Horn Location
this reminds me i need to go through my wiring my horn doesn't work either
Re: Horn Location
mine have all been on the hood, drivers side. 66 is the latest i've owned
Re: Horn Location
Pro tip: Check the relay before looking at anything else. Then tie the horn directly to the battery and see if it actually works.quickgraffix wrote: ↑Tue Sep 29, 2020 1:26 pmthis reminds me i need to go through my wiring my horn doesn't work either
Re: Horn Location
Trucks in my yard.
70 D500. Horns with relay to right of radiator on backside of radiator support between Rad and inner fender.
1968 Fargo. Horns with relay to right of radiator on backside of radiator support between Rad and inner fender.
1968 Dodge. Horns with relay to right of radiator on backside of radiator support between Rad and inner fender.
1967 D300. Dual Horns with relay to right of radiator on backside of radiator support between Rad and inner fender.
1966 W200. Had dual horns on hood rear support with relay on drivers side under hood
1966D100. Had a single horn on hood rear support with relay on drivers side under hood. Evidence it did have a second horn at one time.
I have also removed dual horns with wiring harness from the hood of a 66 D series that are put away for my 66 W100.
