440 chrysler in 1970 d100 shorbed? kinda urgent,
- City: las vegas
- State: NV
well im getting a free motor if i want it, i just gotta remove it, its from a 1979 beaver RV but its a chrysler 440. he has a lil under 50k miles on it and it starts right up and idles perfectly fine. Friend is scrapping the RV tomorrow. SHould i waste my time taking the engine out of it, or say screw it and let the engine go bye bye
- mopardwh
- City: Longview
Re: 440 chrysler in 1970 d100 shorbed? kinda urgent,
Well sure. Do you want a 440 or not??? 79 might not be the best year for one, but it's still decent power. ![Thumbs UP :Thumbsup](./images/smilies/icon_thumright.gif)
wow, if the motor is good, not cracked and rebuildable, get it!!! 440s are getting more and more rare. 79 was the last year for the awesome 440. The fact that its motor home might be in your favor. Many years motor homes had better cooling potential due to water jacket differences. Do some research on this. Your 79 440 block can be made into a screamer with a few bolt ons. TAKE IT
I would!!
I would!!
Be prepared to replace the water pump, timing cover and heads...the motorhome versions have a special water pump and timing cover, external coolant ports in the heads and most of sodium vapor filled valves...aside from that they're alright...just consider them a core motor that needs a rebuild...free is always good...
- WD
- City: Rosemark
If it's a 440-3 it's well worth saving. Heavy duty service engine. They aren't screamers but the torque will surprise you. I've got a 413-3 in a motorhome here, I'd love to stuff it in my 69 D100 but the motorhome is one of 800...
Ruiner wrote:Be prepared to replace the water pump, timing cover and heads...the motorhome versions have a special water pump and timing cover, external coolant ports in the heads and most of sodium vapor filled valves...aside from that they're alright...just consider them a core motor that needs a rebuild...free is always good...
I think you are talking about the 413. There are plenty of 440's used in motorhomes that are are same as in pickups.
