hey everybody
heres my stupid question for the week! ill be building out my poly engine and im not really a fan of the 3 on the tree. im really wanting a floor shift 4 speed. what tranny should i be looking for to handle 400ish hp? thanks for any suggestions!
4 speed manual
- flyngreenmole
- City: Sandy
4 speed manual
your only crazy until your not!
Re: 4 speed manual
Not a big fan of the column shift in the relatively tight cab of my '65, so I understand.
The A833 4 speed should definitely handle that level of power. There was even an overdrive version used in the trucks.
- flyngreenmole
- City: Sandy
Re: 4 speed manual
thanks baker! ill start looking around. i like the idea of an overdrive...
Re: 4 speed manual
The A833 4 speed will not work with your Hydro. set up. The 10 spline NP435 would be a direct fit. Do you have the e brake on your existing A745 3 speed?
Re: 4 speed manual
You can put in an A833 OD trans but will need all the accompanying mechanical bell housing parts, Flywheel etc to install trans into a 68 and earlier. Manufacture a bracket to use Hydraulic slave and a trans crossmember.
Existing crossmember for hydraulic bellhousing mounts may have to be cut out for clearance.
Re: 4 speed manual
Brewer's is a great source for anything A833. Very helpful.
As the others have mentioned, it's not easy, but it is doable.
