test trying to figure out how to post picsmy new 68 D 100
- City: simms
- State: MT
my new 68 D 100
- City: simms
- State: MT
Re: my new 68 D 100
test
- City: simms
- State: MT
Re: my new 68 D 100
I think I got it Happy New Year to all Jerry
Re: my new 68 D 100
Did you convert it to 4 wheel drive?
- City: simms
- State: MT
Re: my new 68 D 100
No from the factory stock 318 4 speed
Re: my new 68 D 100
Nice truck.
Did they make a lwb w100 in 1968?
- powerwagon54
- City: Washougal
Re: my new 68 D 100
no 1st 1/2 ton 5 lug 4x4 was 69
Re: my new 68 D 100
Single stick T-case or twin stick?murphyslaw wrote:No from the factory stock 318 4 speed
- City: simms
- State: MT
Re: my new 68 D 100
thanks for the welcome ....I think it is a 68 that is what the title says, single stick transfer case. Am looking for some defroster vents, black armrests,maybe a stock original radio thanks
Re: my new 68 D 100
That truck was pieced together by someone. A D100 would be 2 wheel drive. A factory 68 4 wheel drive truck would use 8 lug axles, which those aren't. A 68 would have a twin stick transfer case selector as well.
Re: my new 68 D 100
Based on the "68" title, hood, grill, interior, it appears obvious to be a 68 D100 with 69-71 W100 running gear swapped in.
- City: simms
- State: MT
Re: my new 68 D 100
thanks for the info so what yr do you think this truck is? the vin# doesnt say what yr or does it? I just got this so still trying to figure everything out thanks
- City: simms
- State: MT
Re: my new 68 D 100
oh sorry vin# is 1187059609
Re: my new 68 D 100
Run it thru the Registry here:
http://www.sweptline.org/SweptlineRegistry/index.php
It is:
US Serial Number 1187059609
Year 1968
Make Dodge
Model D100
Engine 318LA V8, 383 V8
Plant St. Louis, Missouri
Wheelbase 114, 128
Rating 1/2 Ton
Build Number 39610
D100 = 1/2 ton 2wd
It is:
Year 1968
Make Dodge
Model D100
Wheelbase 114, 128
Rating 1/2 Ton
Build Number 39610
D100 = 1/2 ton 2wd
- City: simms
- State: MT
Re: my new 68 D 100
thanks for the info
- pwadventurer
Re: my new 68 D 100
it looks like you have a 69 front bumper as well, check right front frame rail for serial number to see if it matches tag.
- City: simms
- State: MT
Re: my new 68 D 100
thanks pwradventurer the frame# matches the cab#
Re: my new 68 D 100
Does the truck have a hydraulic clutch?
Re: my new 68 D 100
If it doesn't John, it would be more cobbled than even you would do!Hobcobble wrote:Does the truck have a hydraulic clutch?
