In dash shifter issues
DodgePodge
City: Dallas
Post by DodgePodge »
Greetings!
I have a 65 D200 with in dash shifter. I could engaged PRND all within the P and N range. Seeking the gears.... Now, after I shifted the shifter up and down a few times Full range motion from the P setting to low and back, it will only now engage in Low 1.
Any help to clean or adjust is greatly appreciated
chilort
City: Cookeville
Re: In dash shifter issues
Post by chilort »
Broken cable?
jeffc57
City: vancouver
Post by jeffc57 »
It should be a 2 cable shifter. Is PARK working or is it in neutral at any point? IS it in gear only in first and reverse? or just 1st? Have you done a pan drop and filter change?
Get the book.
Factory Service Manual.
http://www.autobooksbishko.com/
DodgePodge
City: Dallas
jeffc57 wrote:
Wed Mar 22, 2023 5:23 am
Paperwork show the previous owner had the transmission serviced 6 years ago. I do not know what "service" was so I will be changing the fluid and filter. The gear selector would find P, R, N and Ds. Since I ran the selector full range, it will Park and Low gear only.
jeffc57
City: vancouver
Post by jeffc57 »
first and reveres use same band inside the trans, so may only be a "detente" adjustment were the cable enters the trans.
Trans service would be drop the pan and replace filter and lost fluid/gasket.
I will assume the kickdown is hooked up and adjusted, has the carburetor been replaced since you got the truck and is it is stock stromberg ?
Trans fluid level up to the mark when running warmed up neutral, not park, nice clean clear light red fluid with no black specks in fluid?
just trying to eliminate possible issues, assuming it was running right when you got it.
DodgePodge
City: Dallas
I found 2 cables. No evidence of anything broke. Only Drive and somewhat of a Park works. Most of gear selector tension in felt from P to N. Then it feels loose as you lower the selector
jeffc57 wrote:
Thu Mar 23, 2023 6:55 am
Get underneath and watch the cables while someone inside operates the shifter. If a cable doesn't move, then its broken, likely where it connects to the shifter. Or you can remove the shifter from the dash and examine it while you operate it to see if the cables move. Its a simple process to determine if they're broken or not; hell to get a replacement and fix it if they are.
jeffc57
City: vancouver
Post by jeffc57 »
In general I agree with PWD, However, since the cable enters the case you will not be able to see the cable at the trans end, you should be able to hear it shift inside the case with a automotive stethoscope, or by ear ( last year of this application, only year with 2 cables ). If it turns out that the trans needs a rebuild make sure that the shop uses the same valve body that is in the trans, as it is a one year only valve body and hard to find; all other part should be available for a rebuild.
jeffc57 wrote:
Tue Mar 28, 2023 5:52 am
Shift cable at the transmission is external. Easy to see the shift lever move through all positions as Terry mentioned. :Thumbsup
IMG_7502 (2).JPG (14.19 KiB) Viewed 9251 times
jeffc57
City: vancouver
Post by jeffc57 »
On a 65 trans the cable goes inside the trans and the photo posted in the above post is for 66 and up trans, https://imageevent.com/jeffc/techstuff3 ... =4&x=0&p=7 shown in photo 8
jeffc57 wrote:
Wed Mar 29, 2023 5:17 am
:Thumbsup
DodgePodge
City: Dallas
Txas2step wrote:
Tue Mar 28, 2023 6:13 am
The Gear Shift Cable broke at the selector. Now what?
DodgePodge
City: Dallas
DodgePodge wrote:
Tue Mar 21, 2023 7:25 pm
Greetings!
Turns out the Gear Shift Cable broke at the selector. Broke right at the connector Now what?
That is likely something that will have to be fabricated. Not sure who does that kind of thing, but cables are still used in gear shifter & parking brake applications.
Since you still have yours at least it can be used as a pattern for a new one.
nutz
City: phillipburg
Post by nutz »
think summit racing has a universal cable kit
make sure its long enough
jeffc57
City: vancouver
Post by jeffc57 »
might check with Wildcat Mopars in Sandy,Oregon, can look them up, closed Sunday and Monday https://www.wildcatmopars.com/
DodgePodge
City: Dallas
nutz wrote:
Sat Apr 01, 2023 7:37 pm
universal for 2 cable shifting?Awesome!
DodgePodge
City: Dallas
jeffc57 wrote:
Sun Apr 02, 2023 6:27 am
Great!
