Motor identification
- Strongbuilt
- City: Morgan
- State: UT
How do I identify What motor is in my 1965 dodge power wagon D-200 4 door Truck. I have a casting number on the front left of the motor but its for my intake manifold...
Re: Motor identification
Is it a V-8?
If so it is most likely a A318 Poly
Is the distributor toward the back of the engine? Are the valve coversStrongbuilt wrote: ↑Wed Jan 31, 2018 2:59 pmHow do I identify What motor is in my 1965 dodge power wagon D-200 4 door Truck. I have a casting number on the front left of the motor but its for my intake manifold...
scalloped on the lower side and held on with two top bolts?
- pismopowerwagon
- City: Caldwell
- State: ID
- Strongbuilt
- City: Morgan
- State: UT
- Strongbuilt
- City: Morgan
- State: UT
Yes the distributor is toward the back, I do not know what scalloped means. I will post a picture if it will let me. I think they are help on by multiple bolts though..Hobcobble wrote: ↑Wed Jan 31, 2018 6:50 pmIs the distributor toward the back of the engine? Are the valve coversStrongbuilt wrote: ↑Wed Jan 31, 2018 2:59 pmHow do I identify What motor is in my 1965 dodge power wagon D-200 4 door Truck. I have a casting number on the front left of the motor but its for my intake manifold...
- Strongbuilt
- City: Morgan
- State: UT
No there is a plate with grooves cut out for them to sit in, on top of the valve covers.pismopowerwagon wrote: ↑Thu Feb 01, 2018 9:06 amSpark plug wires going through the middle of the huge valve cover?
- Strongbuilt
- City: Morgan
- State: UT
By the way, thank you
If the lower sides of the valve cover are jagged and not straight and are heldStrongbuilt wrote: ↑Thu Feb 01, 2018 10:41 am
on with two bolts on the tops of the valve covers, the engine
is likely an A318 Poly. If there are 6 bolts holding the valve covers on, it could
be an LA318.
This is an A series (Poly) 318 looks like. Notice valve covers and exhaust manifolds.
- zachkennedy
- City: Hamburg
- State: MI
On the block behind where your starter is... should be an identification there....write the numbers down and gooooooooogggggllllleeeee.... Should tell you right there.
Should be XXXXXXX-XXX-XX
- Strongbuilt
- City: Morgan
- State: UT
It looks identical to the 318 poly above! Thank you so much! 2 bolts holding the valve covers!
