medium duty dodge engine mount question
does anyone have a big block medium duty that I can see pics or s description of where the horseshoe mount bolts to the frame? is the rubber mount on the engine or the frame? thx
- powerwagon54
- City: Washougal
Re: medium duty dodge engine mount question
Here is the mount that bolts to the front crossmember. I may have the horseshoe also, just have to look.
http://www.61-71dodgesweptlineparts.com ... ine-mount/
so is the rubber block broken on that one? looks like it should have studs coming out the top
- powerwagon54
- City: Washougal
yes the mount is broken
ok great those pics helped. I will post about what I am trying to figure out after I do. thanks
- City: Torrance
You can always use a hockey puck. Don't laugh. Vulcanized rubber lasts forever. Thats what I used. And they make for great body mounts.Kaegi wrote:does anyone have a big block medium duty that I can see pics or s description of where the horseshoe mount bolts to the frame? is the rubber mount on the engine or the frame? thx
1962 Fargo Torrance, CA
I have a BB400 Bolted into my 70 D500.
the reason I am asking this is because I bought a 61 D300 someone put a 361/5speed out of a S500 school bus chassis. the front mount bolts to front crossmember in factory holes and the tranny mounts bolt in fine in stock location. but the engine looked too low. I had someone with a 383 powered, 67 w300 take some measurements and I was right the front in mine ends up about 1.5 inches too low. so I was going to space up the front mount. then I looked at a D500 with small block and it mounts about 1.5 inches higher on front crossmember so I might just switch out that piece to my truck. or just space up the school bus piece. the school bus bracket is much more HD than the D500 small block piece. This is good new for anyone wanting to convert to BB. don't need to find the rare factory side mounts from 1 tons. lots of medium duty out there to get parts off.
