Carter 9626sa
Caleray
City: Laporte
Carter 9626sa
Post by Caleray »
Im trying to figure out which carburetor to use on my 273. Is a Carter 9626sa a good choice for the engine? Will this work ok with a four-speed?
Re: Carter 9626sa
Do you have a 2 barrel or four intake? Carter BBd if 2 barrel/ I have a Edelbrock 1403 ( 500 cfm) on my 1965 273 Dart. That's all the little motor needs. :2cents :Thumbsup
MadMC63
City: Rome
Re: Carter 9626sa
Post by MadMC63 »
I believe that's a AFB 625 CFM carb. Should be fine.
1971 Dodge D100
MadMC63
City: Rome
Re: Carter 9626sa
Post by MadMC63 »
Couldn't send a pic with the PM so here's what I was talking about.
Throttle linkage stud.jpg (10.5 KiB) Viewed 455 times
Throttle cable on the left kickdown on the right.
1971 Dodge D100
