Throttle Cable Length
Lobster
City: Portland
Post by Lobster »
I'm converting my 1964 D200 manual transmission Poly to a Holley 4bbl on a Chrysler Power intake. I need to order the Lokar throttle cable and was wondering what length is best? What is my best option for a gas pedal?
Thanks for all the support so far. I will post photo's when one of my tech friends has time to help me. I'm kind of stuck in the last century...
B
Re: Throttle Cable Length
Lobster wrote:I'm converting my 1964 D200 manual transmission Poly to a Holley 4bbl on a Chrysler Power intake. I need to order the Lokar throttle cable and was wondering what length is best? What is my best option for a gas pedal?
B
I used a 70 to 76 Dart A body throttle pedal with cable in my 66. Worked slick as can be. No floor mounted pedal either. Or use a Dodge Pick up from 72 to about 80. Allows using original floor mounted pedal.
Lobster
City: Portland
Post by Lobster »
Thank you Dodgeboykim! Sounds like I need to make a trip up to Wildcat Auto Wrecking.
B
You will know when you find the correct style. It is all self contained in the bolt to firewall assembly. Cable is part of bracket assembly. Makes for a nice conversion.
Done both my 66 W100 and my 70 D500.
Lobster
City: Portland
Post by Lobster »
Does it matter if it's small block or slant six cable?
chilort
City: Cookeville
Post by chilort »
dodgeboykim wrote:You will know when you find the correct style. It is all self contained in the bolt to firewall assembly. Cable is part of bracket assembly. Makes for a nice conversion.
This is great information. Thank you for sharing. Looks like I'll be making a JY run next week.
Lobster wrote:Does it matter if it's small block or slant six cable?
I think the ones I used were SB. SL 6 cable may be longer but can still work. Just loop if you have to. :thinking
