Door Locks
flammulator
City: germany
Door Locks
Post by flammulator »
Hello from germany.
The keys from the doors of my truck are loosen by the pre owner.
I have bought a new set of locks with keys.
They doesnt fit. To small.
I read that several Trucks have bigger ones.
I have the ones with the bigger outer diameter.
Can someone tell me where i can buy it. I didnt found something.
Thank you !!
GMAN69
Re: Door Locks
Post by GMAN69 »
I'm not sure what key you need. I just put a set of electric door locks, on my 69 d100. Kit has two remotes and two door motors,and electronics for about $60 us. They work well so far.
Re: Door Locks
A locksmith should be able to make new keys for your locks....at least here in the U.S. Locks are the same '61-'68...maybe through '71. The correct ones pop up on Ebay , but not available through regular sources like Rockauto( wrong ones listed).
might try this guy he has listed the correct ones on ebay before.
http://www.ebay.com/usr/gerardleblanc?_ ... 7675.l2559
Re: Door Locks
Txas2step wrote:A locksmith should be able to make new keys for your locks....at least here in the U.S. Locks are the same '61-'68...maybe through '71. The correct ones pop up on Ebay , but not available through regular sources like Rockauto( wrong ones listed).
Door locks are 61 to 66. 67 Changed to push button outside handle so locks are the same 67 to 71 and up to 75 depending on truck model. C series trucks push button doors use same locks. A 100/108 series Vans/pick ups with push button should also use same locks but that would have to be confirmed. I have door locks and ignition from a C series 900 truck 1973 year in myW100 truck.
(68 doors)
