Axle Swapping
LC
Axle Swapping
Post by LC »
LC from PA working on a 1976 Dodge Custom 100 Warlock 360 727 9 1/4 rear end I also have a 1971 D-100 6cyl manual 3 spd 8 3/4 rear end 3.91 Posi ? is can I just unbolt the U bolt Brakelines ETC and just swap rear end ? can,t find any perch measurements in my manuals Has any one try this or got input to help me out Thanks LC :study :study :study :salut
Re: Axle Swapping
Pretty much a bolt in. You might need the 71 shock/U bolt brackets. U joint and driveshaft length may or may not be the same. Easy to deal with that. :thinking
my5thmopar
City: Columbia
Re: Axle Swapping
Post by my5thmopar »
Something wrong with the 9.25? If you're just wanting sure grip get one from the u pull it.
Re: Axle Swapping
Is the wheel bolt pattern same on the axle you want to swap in? Not that it matters if you have wheels/tires for both.
Re: Axle Swapping
712edf wrote:Is the wheel bolt pattern same on the axle you want to swap in? Not that it matters if you have wheels/tires for both.
76 W/D Series 100 and 71 D100 series share same BP.
