Modern (tube-less & split ring-less) Replica Wheels?
DodgeJosh
City: STL Area In IL
State: IL
Post by DodgeJosh »
Hi everyone,
Frustrated to learn with these trucks that no one really wants to work on split wheel wheels of this era anymore, but even if I do I don't like deal with tube tires. I like the factory wheels a lot. Are there any companies that reproduce the '61-'71, more specifically 1964 D200, wheels but modern wheel design that can accept modern tires?
Really don't want to go aftermarket modern styles, but may resort to that.
Re: Modern (tube-less & split ring-less) Replica Wheels?
DodgeJosh wrote:Hi everyone,
You could check with Vintagewheel.com . I don't hold out much hope for them.
stocktonwheel.com. Possibly you could install your wheel centers into one piece tubeless rims. :thinking
Josh,
Do you have a set of the original "male" dog dish hubcaps for your original
split ring wheels? If not, you can get "close" to factory by picking up a set
of one piece '72-'93 dodge truck wheels. :idea :2cents The later "female"
200 series dog dish hubcaps that came along in '69 would work on the
'72-'93 wheels. :dance
Also, if you can find anyone with a set of original 17.5" Dodge truck wheels
for sale, that is another possibility. These were used somewhat regularly on
200 Series Sweptlines. One other option that comes to mind is the factory
Dodge 19.5" wheel..... but they're a bit tougher to come by.
For any of the original period Dodge truck wheels.... their width doesn't
allow for a very big tire.... so if you're after some beefy tires.... I'd say
aftermarket is probably your only choice. :2cents
DodgeJosh
State: IL
Post by DodgeJosh »
I've attached a picture of my truck below. So not sure what style these are called.
I'm leaning towards just modern 8x6.5 bolt pattern wheels and wider so I could have wider/beefer tires. I thought about somehow figuring out how to mount the caps so I have a mixture of modern wheels with the classic caps in the center look.
WD
City: Rosemark
Post by WD »
If the caps pop over a stamped in ring, you can use Ford wheels. If they pop into the stamped in ring, you can use GM wheels. Do you have 9" or 10" caps?
8 on 6.5" is the industry standard from sometime in the 60s until current. 3/4 through 1.5 ton. Brand does not matter, Dana 60/70, GM 14 bolt, and Ford/Sterling 10.25 all have the same bearing housing outer dimension within less than a hair thickness. I've mixed and matched them at random on a couple trucks, single rear and dual rear wheel.
WD wrote:If the caps pop over a stamped in ring, you can use Ford wheels. If they pop into the stamped in ring, you can use GM wheels. Do you have 9" or 10" caps?
I think the hub hole on GM wheels is too small in diameter. :thinking
Its been a few years since I tried it.... maybe others can confirm this
either way. :study
Johninky
City: elkton
State: KY
Post by Johninky »
True. GM wheels do not fit Fords/Dodges/Internationals and don't know about Jeeps.
WD
City: Rosemark
Post by WD »
Johninky wrote:True. GM wheels do not fit Fords/Dodges/Internationals and don't know about Jeeps.
The wheels on the neighbor's F350 came off a few wrecked 88-98 Chevy K3500s... And we did not have to do any grinding to fit them. $10 each at pull-a-part.
G M 8 on 6.5 can be easily made to fit onto the DODGE's. I have a set on my 66 W100 that had the center hole enlarged to fit over hub. I also had a set on my 76 W200 Dana 60 front/rear. Only about 1/8 inch to remove.
DodgeJosh
State: IL
Post by DodgeJosh »
Little bit of update since this post. So after reading everything saying these are split (locking ring) rim wheels for these trucks and that mine appear like they were, I inspected them better. Since no one wanted to work on them, I decided to take the tires off and see myself.
Well they're not split rim wheels? Only thing I can think of is someone obviously swapped the wheels from another truck, but these LOOK exactly like Dodge truck wheels of this era. Especially the center dome cap. What is going on? I'm probably missing a small detail to distinguish their shape and probably off a GM or Ford that I'm not aware of.
Check out the pictures below. Happy not to buy new wheels so I'm going to continue with the plan to refinish and buy modern radial truck tires.
coelcanth
City: Brooklyn
State: NY
Post by coelcanth »
my truck came on similar (yet definitely different) wheels with a dual bolt pattern and i just assumed they were a cheapish aftermarket option to fit many different trucks.. ?.
the domed baby moon chrome center caps have a paper label on the back that says 'made in taiwan'
i like the way they look and they're round so they'll stay
DodgeJosh
State: IL
Post by DodgeJosh »
coelcanth wrote:my truck came on similar (yet definitely different) wheels with a dual bolt pattern and i just assumed they were a cheapish aftermarket option to fit many different trucks.. ?.
That definitely sounds like a cheap aftermarket solution especially being a dual bolt pattern (not saying there aren't some nice looking aftermarket dual bolt pattern wheels).
I'm going with the amount of rust and wear, and the fact they're not a dual bolt pattern and the same bolt pattern as a Dodge D200, that they're probably still from the 1960's or maybe 1970's. Just curious what they're from as they sure do look spot on for D200's from the brochures I've seen and pictures, and baffles me as I initially thought they were split rim.
digdoug
Post by digdoug »
I had 2 of those kind of wheels on a 67 truck.They were made by Kelsey Hayes.
91w350 CTD
93w250 CTD
