I've been looking around for a machine shop in my area (north of Seattle) that I like, is well recommended and 'correctly' priced. It has been a long time since I've had any work done at a shop and I feel like the prices I'm getting quoted are higher than they could be. Here are some examples of prices from a highly recommended shop:
Taken from: Action Autoparts: Machine Shop: Parts and Services
THERMAL CLEAN & MAG BLOCK $137.50
8 CYL [BORING] $203.50
8 CYL [HONING] $137.50
SWEDGE [DRUMS] W/O TURN (STUDS ADDITIONAL) $ 53.50
V8 2 VALVES [GRINDING] PER CYL OHV $182.25
Am I being old and cheap or are these pretty reasonable? Thanks for any input.
Machine shop prices
Re: Machine shop prices
Good
Fast
Cheap
Pick any two, won't be the third
Fast
Cheap
- magnumcid
- City: Sherbrooke
Is it sad that the first place I saw that was on a poster tacked to a garage door in "The Fast and the Furious" (2001)?PwrWgnDrvr wrote:Good
Fast
Cheap
Yep.
I started shopping around for options two years ago when my 318 started to die. I worked in Everett (WA) at the time and found a place in Marysville, Automotive Machine, I think it was called. They quoted me at $4800 (worst case) to rebuild my motor. Yikes! I ended up buying a crate 318 from an out of business engine company in Tacoma for $800.
- Dood
- City: Shoreline
Ugh, thanks for the reply. I priced machine shops to do a hot tank, cam bearings, head work (clean, stems, grind). and it was more than a crate + shipping. I planned on doing disassembly and reassembly myself. I feel like I'm missing something.Bubb wrote:I started shopping around for options two years ago when my 318 started to die. I worked in Everett (WA) at the time and found a place in Marysville, Automotive Machine, I think it was called. They quoted me at $4800 (worst case) to rebuild my motor. Yikes! I ended up buying a crate 318 from an out of business engine company in Tacoma for $800.
