gear oil question
- hemihydro135
- City: tucsonaz
gear oil question
I want to change all the gear oil in my PW, what brand and WT do you recommend for the differentials 4spd trans and transfer case?
- elacruze
- City: Jensen Beach
Re: gear oil question
I use Royal Purple in all my stuff, but it's overkill. Any name brand lube will work, just be sure you don't use a GL-5 rated lube in the transmission; if it gets over 300 degrees F, it will eat the synchros and in any case reduces the effectiveness of the synchros making shifts harder and slower.
What would be best in a NP540 5-speed?elacruze wrote:I use Royal Purple in all my stuff, but it's overkill. Any name brand lube will work, just be sure you don't use a GL-5 rated lube in the transmission; if it gets over 300 degrees F, it will eat the synchros and in any case reduces the effectiveness of the synchros making shifts harder and slower.
Do you have a Factory Service Manual?hemihydro135 wrote:I want to change all the gear oil in my PW, what brand and WT do you recommend for the differentials 4spd trans and transfer case?
