clutch pedal problem
So my clutch pedal doesn't come back out all the way anymore. It stops a couple inched short. I checked the slave cylinder and it appears to have been rebuilt by the previous owner. Haven't checked the master yet. Any suggestions as to what's goin on? Its a 60 with the poly. It does still engage and disengage the clutch. Thanks in advance
Re: clutch pedal problem
When you say "appears to have been rebuilt".... what arestakebed wrote:So my clutch pedal doesn't come back out all the way anymore. It stops a couple inched short. I checked the slave cylinder and it appears to have been rebuilt by the previous owner. Haven't checked the master yet. Any suggestions as to what's goin on? Its a 60 with the poly. It does still engage and disengage the clutch. Thanks in advance
you basing this on? You should check a Factory Service Manual
[FSM] for the proper run-out on the clutch fork and adjust the
threaded rod at the slave cylinder accordingly. If the system
is not currently leaking at the slave, in the line or at the master
cylinder [look under your floor mat too], you might want to re-bleed
the system to ensure that there's no air trapped in the system.
Also, you might want to make sure the pedal shaft is lubed
and the pedals are moving freely on it. Sometimes, the shaft
can tighten up and bind the pedals slightly.
The new looking boot on the slave cylinder.gonna check the master after work and how does one adjust the run in etc...possibly rebleed it as well
Ok not doing it in the rain ... did look and found the adjustment, there is also some adjustment om thr pedal shaft to. Having thought about it some more the clutch is pretty worn, could this contribute?so next non raining day ( man i need a garage) i will check my master and play with thhe adjustmensts some...the master boot does not look nearly as new as the slave
- City: Parker
When I rebuilt my clutch master it was acting like your clutch is acting until it was properly bled. Then it firmed up and snapped right back up how it should.
- Oldguy
- City: Reno
- State: NV
Don't forget to clean and lube the clutch pivot shaft. That really helped on mine.
Mike
Ok did check pedal pivot point.... not sticking there will lube it this evening though. The master makes a suction type noise when i pull the pedal out the rest of the way.it has no visible leaks. Did cind out i have a windsheild gasket leak though. I have only put 48 miles on this truck since i got it last july.would it take that long to show the air bubbles and need to be bled? My hose is a straight shot with no loops. Thanks guys
Ok its gonna be pretty obvious that i am definately not used to older rigs pretty soon. So i checked the fluid level and it was good and looked like new.oh well i thought.i will just do the lube on the oedal pivot area.there it was the whole time, the rubber bump stop had pretty much disentegrated allowing the extra play. Dur be dur guess i shouldn't assume the worst every time something goes wrong. Thanks for your guys help.
- Oldguy
- City: Reno
- State: NV
Now on to that leaky valve cover gasket and putting a stereoin this thing
