could anyone tell me if 5 lug 4 and a half inch bolt pattern wheels will fit on my 71 d100? tires 215 75 15
thanks
robert
wheels and tires
- DB69
- City: La Porte
- State: IN
wheels and tires
what size wheel is it that you are talking about? is it 15"? and if so what is the width? I think that truck takes a 15x5.5(standard wheel size)
DB69
DB69
TommyDodge
1997 Dodge Ram 1500 Club cab 3rd owner 86,330 miles
I don't drive a Ram-I drive a Dodge Ram
Dodge Brothers Detroit USA,
In Memory of Molly and Missy, My Beagle Girls
- wideblock
- City: las cruces nm
- State: NM
d series trucks are 5 on 4.5 bolt pattern, some w's are a larger 5 lug pattern. what you need to watch for is backspaceing. anything more then around 3 to 3.5 inches will rub the steering arm. this is on a 15inch wheel.
- wideblock
- State: NM
id check it first, the newer jeeps have quite a bit of inside backspaceing, they will probably rub. i had a set of 7inch wide rims with 325/75/15's that rubbed, bought the right wheel and stuck a 31/10.50/15 in the same spot with extra clearence. the back space makes all the difference in the world!
