I'm struggling to find hardware for the gas pedal linkage, specifically the bushings for the pivot which bolts to the firewall as well as the clips that keep the pivot from dislocating from the bracket. Is anyone aware of any kits for this? I have pedal side hardware on order from Detroit muscle technologies, but can't find the firewall side items anywhere.
Thanks for any pointers!
Gas pedal linkage hardware - 69 D200
Re: Gas pedal linkage hardware - 69 D200
Have you looked at any Mopar Restoration Parts suppliers. Lots of common little parts were used for both cars and trucks.
- City: Binghamton
- State: NY
The clips you mentioned and possibly bushings may be available from r/t specialties. They have hundreds of different small things like that. They set up in Carlisle for the mopar show. It amazes me how many small fasteners they bring and all of it is new. If it’s available they have it.Baz wrote: ↑Wed Mar 20, 2024 9:15 amI'm struggling to find hardware for the gas pedal linkage, specifically the bushings for the pivot which bolts to the firewall as well as the clips that keep the pivot from dislocating from the bracket. Is anyone aware of any kits for this? I have pedal side hardware on order from Detroit muscle technologies, but can't find the firewall side items anywhere.
Late 65 w 200.
Factory LU-2 winch.
440 repower in the works
60 d100
383 with 727
4 wheel disc
3.73 geared rear
Factory LU-2 winch.
60 d100
383 with 727
4 wheel disc
3.73 geared rear
Thanks all for the suggestions!
What website was this intended for? Unfortunately the filter censored the link out.soopernaut wrote: ↑Sun Mar 24, 2024 7:56 amThese may be the bushings you need:
https://**NOT ALLOWED**.com/brake-clutch-pedal-bushing-4294639/
Weird that it shows up when I look at my post... easy - streetllc.com (take out the spaces)Baz wrote: ↑Wed Mar 27, 2024 11:18 amThanks all for the suggestions!
I see it too, because I have the profanity filter turned off.
Go to user control panel. Select board preferences. Select edit display options. Select no for enable word censoring.
Then you will see it, along with all the proper descriptions of stuff, like: that was a bunch of *#%^ that was a hell of a pain in the @#%.
Its filtered when I see it too.
That fixed it for me, thank you!PwrWgnDrvr wrote: ↑Thu Apr 04, 2024 9:38 amI see it too, because I have the profanity filter turned off.
