Where did you mount your tach?
- chilort
- City: Cookeville
Re: Where did you mount your tach?
I ended up using the mount that came with my tach. I put it on backwards and then clamped it to the dash via the center speaker hole (center speaker is not in use). The tach body itself sets on the dash pad and the whole thing is aimed at the driver position. Hope it stays in place.
- 64D100Poly
- City: Vancouver
I personally put mine on the steering column on the left hand side, I'll post a pic when I get the opportunity.
-1961 Dodge Dart Pioneer
-1968 Barracuda Formula S
OO\===/OO
OO\===/OO
My fuel gauge is in there since I hate add on gauges under the dash. I pulled the old broke tach out and swapped in a working fuel gauge. I plan on getting all new gauges then putting in a vacuum gauge into the tach pod. I can see just fine over the gauge also.
- 64D100Poly
- City: Vancouver
here's a couple pics64D100Poly wrote: ↑Wed Mar 15, 2023 12:31 pmI personally put mine on the steering column on the left hand side, I'll post a pic when I get the opportunity.
OO\===/OO
OO\===/OO
- chilort
- City: Cookeville
Cool to see all the pictures. Mine isn't very subtle on tbt dash but it is working out well so far
- thehemikid
- City: western kentucky
- State: KY
- City: Milwaukie
