Any source for turn signal lenses for a pie plate truck? I'm looking for clear lenses, preferably with gaskets. Thanks!
Darren
Turn Signal Lenses - Pie Plate
- RamZCharger
- City: Houston
- City: Binghamton
- State: NY
Re: Turn Signal Lenses - Pie Plate
Multiple sellers on eBay sell the front turn signals. They are they also fit from a c j 5 jeep but they are clear and the plug is different
Late 65 w 200.
Factory LU-2 winch.
440 repower in the works
60 d100
383 with 727
4 wheel disc
3.73 geared rear
Factory LU-2 winch.
60 d100
383 with 727
4 wheel disc
3.73 geared rear
- RamZCharger
- City: Houston
I have confirmed that the Crown Automotive J8127449 lens fits our trucks, you should be able to find them for around $9 each. These have a faux chrome trim ring.
Hey Darren, the Jeep lamps/lenses work great used them on my '61 and '67. ![Thumbs UP :Thumbsup](./images/smilies/icon_thumright.gif)
- Attachments
- 020 (640x480).jpg (50.94 KiB) Viewed 853 times
just a note- if your using clear lenses you must use 1157A (amber) bulbs to be legal on the road (it not that likely you will be pulled over for it, but can happen)
- RamZCharger
- City: Houston
For lights with clear lenses check these out - https://illumin8s.com/
I have used them on a couple different vehicles, the seller is very easy to work with. While driving the parking lights function like bright white driving lights, and when you activate the turn signal they blink amber. I'm working with the company for a set that will mount in our Sweptlines, they will probably just have long tabs that require a trim. Stay tuned and I'll post when all is worked out
- 64D100Poly
- City: Vancouver
https://www.decadeautoparts.com/ used to sell the clear ones, I don't know if they discontinued them of if they are just temporarily out of stock, they have the amber ones though.
-1961 Dodge Dart Pioneer
-1968 Barracuda Formula S
OO\===/OO
OO\===/OO
