Scarebird Bracket Issue reminder
my5thmopar
City: Columbia
Post by my5thmopar »
I posted this since I've seen a few recent threads about this conversion. I was trying to resolve a strange rattle from a dead stop. I checked all the suspension and steering components for tightness. Nothing found. While researching the issue, I ran across several threads from others about the brackets and/or pads needing to be modified for clearance. Well what do you know...I took mine apart today and neither L/R pad would clear the brackets. The sound was being caused by the pad binding with the bracket and rotor. I also had issue of the truck pulling hard or locking up the RH brake intermittently. Anyway, hope this helps someone else. Craig
Series1Utiline
City: Newberg
Re: Scarebird Bracket Issue reminder
Post by Series1Utiline »
Can you post a picture of what you found regarding the location the pads wouldn't clear the bracket and rotor?
S1U
my5thmopar
City: Columbia
Series1Utiline wrote:
Sat May 30, 2020 6:09 am
S1U
There are several threads on here. I didn't take a picture but, search and look at this picture from @slick. Its an older thread but, I think you will get the idea.
viewtopic.php?f=20&t=35033&p=253792&hil ... ce#p253792
Series1Utiline
City: Newberg
Yes, I had seen that earlier but thanks for the reminder. I did some grind some on my pads at installation so hopefully this isn't an issue for me. However, I not only do not see a "gain" in braking since the Scarebird install, I have noticed a loss in braking efficiency. I'll pull my wheels off and have a look. It may be that I didn't remove enough material.
- S1U
my5thmopar
City: Columbia
Sat May 30, 2020 12:36 pm
- S1U
I have to agree. My manual drum brakes would throw you through the windshield. Now I have power and Scarebird and less aggressive braking. Don't get me wrong, the truck stops smooth and I like the less leg effort but, not like drums. I haven't had a chance to test since the repair. I'm dealing with a leaking axle right now. I'll report back. Craig
Wildergarten
City: Los Gatos
Post by Wildergarten »
The kind of braking for which discs matter is when the brakes are already hot, such as when carrying a heavy load going downhill or towing a trailer without brakes. Drums grab just fine, but can fade when they get hot.
hmaynord
City: fairhope
Post by hmaynord »
Wildergarten wrote:
Sun May 31, 2020 7:16 am
...such as when carrying a heavy load going downhill...
which you minimize on the highway by using a lower gear
harris
driving it since 12/03/71
Wildergarten
City: Los Gatos
hmaynord wrote:
Mon Jun 01, 2020 8:17 am
I almost died believing that.
No engine braking on a diesel w/o an exhaust brake installed.
