Left my key in a different state. I need to hotwire my truck. I can get it to crank, but i believe i need to get it to the on position first. I think i'm missing a step.
Can someone jog my memory. See image below.
What pin to what pin to what pin.
Hotwire a Swepty
Hotwire a Swepty
http://www.Sweptline.ORG
1965 Dodge SWB D100 (Utiline)
1970 Dodge LWB D100 (Dude)
Re: Hotwire a Swepty
Got it.
Wire between BAT to ING2 for power
Touch BAT to ST to start
Scott, I don't recall which one of the 2 IGN's is which, but one bypasses the ballast resistor for starting and the other is the "run" position. Both will work and "run", but if the ballast is bypassed for long, it will burn up the points.
I would run jumper from + terminal of battery to the ballast resister (correct side) . Use screwdriver across starter terminals to crank.
- City: Lawton
You can also run a jumper from the battery to the positive on the battery, then short across the starter relay. However this will throw your charging system into full charge mode so don't run it to long.
Life should NOT be a journey to the grave with the intention of arriving safely with a well preserved body, but rather to skid in sideways, beer in one hand,cigar in the other, body thoroughly used up, totally worn out and screaming,"what a ride"
Check parts store for an ignition switch
I know I’m late but this did the trick.
- MrMopar
- City: Lompoc
Easiest way to do this, too easy.
Alan
Alan Erland
1967 Plymouth Barracuda
1969 Dodge Polara CHP
1969 Dodge Polara
1970 Dodge Camper Special
www.MrMopar.com
1969 Dodge Polara
www.MrMopar.com
