1968 D100 aftermarket brake drums
sambudo
City: Vancouver
Post by sambudo »
Can you buy these at any auto parts locations?
What do you all do?
Re: 1968 D100 aftermarket brake drums
Drums are one of those sought after parts that I think you have to find in a junkyard. I don't know if other vehicles have some that will fit.
Be thankful that you don't have a 6 lug W300.
Jim100
City: Kalamazoo/MI
Post by Jim100 »
The ones listed at Rockauto are not correct? They seem to have a front and back listed?
jim
classiclvr
City: lititz
State: PA
Post by classiclvr »
May fit non finned only. I always thought the straight axle D100 series drums were all the same from '66-71 or maybe '68 -71.
My '71 D100 has the huge finned drums...11 x 2.25 shoe which is the same for '68 and '71 with a 318.
powerwagon54
City: Washougal
Post by powerwagon54 »
finned drums are aftermarket car drums. The factory D100 drums are non finned.
classiclvr wrote:
Wed Jun 13, 2018 10:11 am
I believe the mid '65 through '68 D100 rear drums are the same.
The '69-'71 rear drums were slightly smaller in diameter. Last I
knew, the '69-'71 rear drums were still available on the aftermarket. :thinking
As Bud points out, none of the Sweptlines were originally equipped
with a finned style rear drum. I do not know if the finned drums
are compatible with the factory Sweptline flanged axle and backing
plates. :thinking
As for front D100 drums.... they were the same from '59-'71. :study :2cents
my5thmopar
City: Columbia
Post by my5thmopar »
Jim100 wrote:
Sun Jun 10, 2018 6:41 am
jim
Jim, Did you order one? Regards to fins, who cares if it fits? If the 65-68 are so hard to find, then change the backing plates to a C-body or 69-71 D100. I have a 68 New Yorker diff and it has 11x2.5 on it. Anybody know the spec on the 65-68 and the 69-71. I've misplaced my manual or I could look it up. Craig
Jim100
City: Kalamazoo/MI
Post by Jim100 »
I did not order any. I just looked them up out of curiosity and to try and help with the original question. But I still wonder if Rockauto is listing them incorrectly? Or they don't really have them if you actually try to buy them?
coelcanth
City: Brooklyn
State: NY
Post by coelcanth »
i see a lot of available listings for this centric part no. 123.63005
should fit 1968 according to the websites, but maybe they're wrong or out of stock.
detailed dimensions in the diagram here
i know the quality of aftermarket drums can be pretty low, but maybe worth a try at $50..
Hobcobble wrote:
Thu Jun 14, 2018 8:10 am
plates. :thinking
I'd like to add that the flanged axles started showing up on early '65 D100s. :study
I'm not sure if all early '65s had them or not. I cannot confirm whether or not Dodge
made a complete switch from the tapered axle to the flanged axle at the end of the
'64 model year. :thinking :2cents
classiclvr
City: lititz
State: PA
I went back through this thread and no where that I could see does it mention front drums or rear drums? Rear drums are available through regular parts stores. My front drums are not available in the aftermarket. They are the 11 x 2.25 and are finned and original.A 1971 Dodge 2wd d100 with a 318. Rockauto lists front drums for a '68, but are not finned and fit 1959-69.
DraytonCalhoun
City: Jacksonville
Post by DraytonCalhoun »
My ‘68 the front and rear drums are identical. From what I’ve read and heard, towards the end of the model year that’s not uncommon.
jeffc57
City: vancouver
Post by jeffc57 »
D100 front brakes should be 2.5 shoe, rear should be 2 inch shoe, brake drum on the rear should be not as deep on the rear 65 to 68; drums are both 11 inch. 69 to 71 should use a 10 inch drum on the rear (2.5 shoe), 11 on the front
