Brakes locking down
- City: Eakly
Brakes locking down
Been working on my 62 D100 and finished my Scotts IFS swap in front and have taken it for a couple drive and have noticed the front brakes which are now disc seem to not want to release fully and my brake pedal is very stiff with little travel. Have new rear drum brakes that are adjusted properly. Have the factory single reservoir master cylinder, non power. Do I need to replace the distribution block on the frame with a adjustable proportioning valve? Anybody run into this before?
Brandon in Oklahoma
Brandon in Oklahoma
Re: Brakes locking down
Do u have any old, original, rubber flex lines in the front?
- City: Eakly
No their new braided steel lines to the calipers in front and the rubber line at rear brakes is a new one. Thanks.
Brandon
Brandon
If going to disc brakes I thought I read here that one needs to use a disc brake master and also use an proportioning valve?
This was for a disc dana 44 swap but seems like it would be the same?
jim
jim
You need a dual disc/drum master and I used a disc/drum dist. block I purchased on Ebay. ![Thumbs UP :Thumbsup](./images/smilies/icon_thumright.gif)
I don't think front disc/rear drum is going to work with a single reservoir master cylinder.
soopernaut wrote:I don't think front disc/rear drum is going to work with a single reservoir master cylinder.
And you have no safety back up with a single master cylinder if something goes wrong.
I don't remember for sure, but doesn't the stock master cylinder have a built in residual valve? That could cause some interesting issues with front discs.
'63 D100
- City: Eakly
Ya I know that it would be better with a dual master cylinder reservoir, but I'm not the best about flaring brake lines, ha. Was wanting to just stick with the single reservoir if I could. Thanks.
Brandon
Brandon
There is an RPV in the stock master. That is your problem.
Why would you go to all this trouble to swap in disks and not do the job right and safe? (dual master)
Mess with the brakes, hurt someone in an accident, their atty will rip u apart and your insurance company will probably not cover it claiming u defectively modified it.
- City: Eakly
Ha didn't know I was going to get griped out, was just wanting some advice. Thanks for all the help, I went with the single reservoir cause it was new and didn't think of it causing an issue and the way Im going to drive the truck in rural western Oklahoma with not much traffic and a all new brake system didn't think I would have a issue of a leak that I would loose the fluid. Thanks, I'll get it changed.
Brandon
Brandon
Just curious... what is an RPV?PwrWgnDrvr wrote:There is an RPV in the stock master.
Jims68 wrote:Just curious... what is an RPV?PwrWgnDrvr wrote:There is an RPV in the stock master.
Residual Pressure Valve. The aftermarket ones keep approx 2-10 psi remaining in the brake line to prevent the wheel cylinders from completely retracting, kind of like an infinitely adjustable brake adjuster... Not sure what value the stock one leaves in the system, but probably pretty close.
The only time I've ever seen them used with disc brakes, the 2 psi fixed valves were used when the master cylinder was mounted below the floor to prevent a backflow situation.
'63 D100
Thanks! See? Ya learn something everyday!BigJimG wrote:Jims68 wrote:Just curious... what is an RPV?PwrWgnDrvr wrote:There is an RPV in the stock master.
- City: Eakly
Great Info soopernaut, thanks a lot!!!!!!!!!
Brandon
Brandon
only way to keep the single reservoir is to take apart the master cylinder, remove the residual pressure valve, buy a remote mounted 10 psi residual valve and install it on the line that goes to the rear brakes. you dont need a residual valve for disk brakes unless you are running an older car with nan under the floor mater cylinder.
