Hopefully this picture works, it was being weird at first.
I am new to the forum (first post). Just bought my first truck. It's a '71 D200 Longbed Camper Special....
Going to slowly buy parts and fix it up. I don't want to paint it, yet.
It has the original wheels. What size tire would you recommend putting on it? The current ones are 285/75/16, and I think they are a little big.
Thanks!!
David
1971 D200 Camper Special
"If you want me to agree with you, I can, but then we'd both be wrong."
Does anyone know what color this truck is? I can't find any color codes or color matches at all.... I need to touch up the inside door panel, but I can't find any paint to match.
David
OKCSweptline wrote:Does anyone know what color this truck is? I can't find any color codes or color matches at all.... I need to touch up the inside door panel, but I can't find any paint to match.
Not sure looks gold-ish but, I don't think that color was offered in 71. Maybe medium tan 2219 or light tan poly 2217 . Hang on someone else will chime in.
I don't think it is any kind of tan... It is more green than anything. If you look at it close, there is almost a gold looking tint in the green.
I figured if it was painted, I could find the original paint color somewhere... But the entire truck is this color... I'm stumped.
David
Apparently some of the 1970 colors were still available as a spring color and carry over in 71. So its possible it is one of 70. Do a google search and there are several paint references online.
I have a '71 W200 that is gold from the factory. Under the gold, is a similar color tonally that was the under the metallic gold color--and it looks a lot like your truck. What's (color) under the hood?
I like your wheels fine. download/file.php?mode=view&id=33081
63 W200 318/420 service body
69 D300 318 dual dump
71 W200 383/A727/ Camper Spec.
Funny how that works. My truck is light green metallic or so I'm told. There are places all over the truck that really have a lime green appearance. I even pulled the gas tank only to have the same confusion persist. I used a Google search only to have absolutely no clue still. I'm told some body shops have an electronic tool that can tell what the color is. You just need an area that hasn't been affected by the elements in order to get a true color match. All of the patina 'ed paint is a thing of the past. The newer paints will never look this way again with aging.
I'm just gonna go with spanish gold iridescent aND be done with it. Lol. Doesn't really matter to me, I was just curious. This is the only d200 I've seen in the same color.
David
