This is the only image I have of it right now. Ill be finishing it up in the next week or so, so Ill get ya some pics by then.
This is the fuel injected stainless tank I made.
Here is the sump I made, that little fitting with the tabs on it took me a few hours on the lathe to make. I first cut the I think 1 1/2" solid plate into a circle on the water jet, then I went to town whittling it down. The four little holes is where a rubber check valve sits, and the fuel pump sock clips onto the bottom lip and two tabs. Then I tig welded it all together. I had just bought a little dragster85 thermal arc (or dynamic) stick/tig welder. This was the first thing I tig'd together with it. works pretty good, and it is a super small package, a 6 pack of beer is bigger then this welder. All that work to be never seen again.
Here is an inside shot of the baffles and trap doors I made insdie the tank before I welded the sides on. The fule pump sump sits inside the square box that has the three trap doors in it.
Here is the a100 seat brackets I made for it. out of aluminum. I had them powder coated semi gloss black.
![Image](http://i5.photobucket.com/albums/y164/cageman1/2013-02-18_16-38-47_725.jpg)
