front fender
- paffuffnic
- City: CORONA
front fender
I think I posted my question in the wrong place before. I am trying to remove the front fender on my 69 D100. All of the bolts are out, but there seems to be some kind of fastener at the cowl where it meets the fender. Do I have to remove the door and the hinge pocket??
Re: front fender
Up on your kick panel, there is an access hole covered bypaffuffnic wrote:I think I posted my question in the wrong place before. I am trying to remove the front fender on my 69 D100. All of the bolts are out, but there seems to be some kind of fastener at the cowl where it meets the fender. Do I have to remove the door and the hinge pocket??
a plastic Caplug. Remove the plug and you'll see a 1/2"
head hex bolt. A lot of times, the kept nut will twist out
of its housing.... just so you know.
- paffuffnic
- City: CORONA
Re: front fender
Thank you. I just now spotted the plug, and was suspicious . . . .Thanks again, Bruce
- paffuffnic
- City: CORONA
Re: front fender
Fender is off and keptnut did not twist (WD-40 overnite). Thanks again John.
Re: front fender
Good deal.paffuffnic wrote:Fender is off and keptnut did not twist (WD-40 overnite). Thanks again John.
NOT spin out of that keeper in my life.
Re: front fender
Same here John. I'd have to say out of all the fenders I've removed, which up to about probably about twenty or so, I'd say only three didn't spin.Hobcobble wrote:Good deal.paffuffnic wrote:Fender is off and keptnut did not twist (WD-40 overnite). Thanks again John.I've probably had one kept nut
NOT spin out of that keeper in my life.![]()
Well done!!
http://www.Sweptline.ORG
1965 Dodge SWB D100 (Utiline)
1970 Dodge LWB D100 (Dude)
- paffuffnic
- City: CORONA
Re: front fender
Thanks all. No one asked why I had to take the fender off. I ran into something with it. Made me sick. Someone hit my Honda CR-V and it didn't bother me that much, just took it to a body shop and got it fixed. Someone backed into my Dakota, it didn't bother me that much, they tool care of it. But...........................when I bent the fender on my 69 D100, it almost made me sick. My wife thought I was crazy, thought she saw a tear in my eye (she did). It is amazing how you can feel about these sweptlines
. Bruce
Re: front fender
I gave up and just welded new nuts in mine. If I had thought about it I prob would have put bolts on instead...
1966 uti rebuild from hell
- paffuffnic
- City: CORONA
Re: front fender
I used my newer Dodge to help fix my older Dodge. Hooked a come-a-long to the trailer hitch of my 01 Dakota, and put an eye bolt thru the core support of my swepty and pulled it out. Fender is back on, straightened grille, put in new headlight, bumper is in chrome shop, and just have to pull the dent on the rt end of the hood and refinish the hood and fender. I would post pictures, but it really is a hassle. My system just doesn't match the system you have.
Bruce
Bruce
Re: front fender
Hobcobble wrote: ↑Wed Sep 01, 2010 1:47 pmUp on your kick panel, there is an access hole covered bypaffuffnic wrote:I think I posted my question in the wrong place before. I am trying to remove the front fender on my 69 D100. All of the bolts are out, but there seems to be some kind of fastener at the cowl where it meets the fender. Do I have to remove the door and the hinge pocket??
Anyone know where to purchase those plastic caplugs?
Brett Pitts
'64 D200 318 Poly
'64 D200 318 Poly
Re: front fender
Try Restoration Specialties online catalog: Pages 223,224,225paizao99 wrote: ↑Tue May 01, 2018 12:43 amHobcobble wrote: ↑Wed Sep 01, 2010 1:47 pmUp on your kick panel, there is an access hole covered bypaffuffnic wrote:I think I posted my question in the wrong place before. I am trying to remove the front fender on my 69 D100. All of the bolts are out, but there seems to be some kind of fastener at the cowl where it meets the fender. Do I have to remove the door and the hinge pocket??
1970 W200
318, NP 445
Factory LU-2 winch
A/C, HD Gauges
318, NP 445
Factory LU-2 winch
A/C, HD Gauges
