Front fender removal
hampstead38
City: Denton
Re: Front fender removal
Post by hampstead38 »
This is look at the firewall. The nut in the bottom center holds a rod that braces the fender.
hampstead38
City: Denton
Moving to the passenger side, this is a picture of the fender brace rod. You can see the ugly rot where the double bolts attach the fender to the bottom of the cab.
hampstead38
City: Denton
Staying on the passenger side, I tried to get a picture of the round mounting surface on the inner firewall. You can see the oval rubber flap where the cowl drains (supposedly). You can also see the heater hoses as a point of reference. The hood hinge has been removed.
hampstead38
City: Denton
This is an ugly rot close up.
hampstead38
City: Denton
I hope that helps.
vetto
City: Oakdale
State: CT
Post by vetto »
that's amazing, thanks! Exactly what I needed :Thumbsup . I will post what the same thing looks like without any metal later this evening. ;)
1971 D200 Crew Cab (The rust was FREE!)
My Build Thread
Oldguy
City: Reno
Post by Oldguy »
Okay. More pics. The upper part of the fender then the bottom of the fender where it bolts to the cab. Then the front of the fender at the bottom where the brace bolts on and then the place where the fender bolts to the cab at the top of the fender. Good luck Mike
Remember, if you run out of projects, you die!
http://pics.livejournal.com/mikescars/
vetto
City: Oakdale
State: CT
Post by vetto »
What it's NOT supposed to look like
Here is the passenger side
Front the passenger front tire looking back
and the driver's side
Front the Driver's front tire looking back
From low behind the Driver's front tire looking back along the frame
Note that "L" shaped bracket that is broken? Is that a separate piece or is it part of the fender?
I am missing a ton of metal from the looks of your pictures. :banghead
My Build Thread
Oldguy
City: Reno
Post by Oldguy »
Man! I can't believe some of those pictures. I guess I'm spoiled living here in the desert. Looks like someone is going to be able to hone their metal working skills. Good luck guys. Mike
hampstead38
City: Denton
The cab I shot pics of is my parts truck... not that the project truck is rust free by any means.
