Flywheel needed
Flywheel needed
Does anyone have a flywheel for a 68 d100? It's for a225 slant 6, 172 tooth, 11" clutch. I cant find a replacement.
Re: Flywheel needed
I am inclined to believe the 68 & back V8 truck engines also used that same 172 tooth flywheel, but I'm not certain.
And while searching I came across 172 tooth flywheels in Chrysler V8 marine applications.
There is a slant six website that probably would know.
Re: Flywheel needed
How about this. Are there any other flywheels that would bolt up and maybe only require me getting a new starter?
Re: Flywheel needed
I think I have one
Re: Flywheel needed
That would be great!
Re: Flywheel needed
I do have one. PM me
Re: Flywheel needed
if I recall rite the slant has one bolt that is offset different than the V8 crank, hole can be slotted without issue
Re: Flywheel needed
I found a guy who resurfaced it and put a new gear on it. Im all good now. Thanks!
Re: Flywheel needed
the flywheel is determined by the size of the bellhousing.
