Headlight Bezel
Headlight Bezel
Can anyone tell me what type of fastener was used on the 1968 grill to headlight bezel and where I might source one? The bezel was missing when I got my truck. Starting from scratch. Thank you.
- Attachments
- headlight_small.png (193.16 KiB) Viewed 1489 times
1968 W100
1967 Plymouth Barracuda
Re: Headlight Bezel
would think the little square plastic inserts
Re: Headlight Bezel
I just pulled a screw out of mine a 68' and the hole is 1/4" x 1/4". A quick Google search found some on ebay for $9 in a pack of 25.
Try ".25" x .25" plastic insert headlight bezel mopar". Ford inserts came up but they should work. I'll post a pic asap.
Re: Headlight Bezel
Jimharold
Re: Headlight Bezel
Thanks for the pic. I do have the square plastic inserts now however they seem to push the bezel out more than they should? Will keep working on it.
1968 W100
Re: Headlight Bezel
grind the top off a little
Re: Headlight Bezel
- 64D100Poly
- City: Vancouver
Re: Headlight Bezel
All of my clips were broken on mine, I went to O'Reillys and found in the Dorman Help section identical push-in nylon nuts that were labeled under a Kia bumper retainer.
-1961 Dodge Dart Pioneer
-1968 Barracuda Formula S
OO\===/OO
OO\===/OO
- martincom
- City: Five Points
Re: Headlight Bezel
If you think of it, would you get and post the Dorman PN?64D100Poly wrote: ↑Wed Mar 09, 2022 9:54 amAll of my clips were broken on mine, I went to O'Reillys and found in the Dorman Help section identical push-in nylon nuts that were labeled under a Kia bumper retainer.
- 64D100Poly
- City: Vancouver
Re: Headlight Bezel
Dorman 961-302D64D100Poly wrote: ↑Wed Mar 09, 2022 9:54 am
OO\===/OO
OO\===/OO
- martincom
- City: Five Points
Re: Headlight Bezel
Thank you!
