Fender SIze
Fender SIze
Please confirm that all fenders (61-71) are the same dimensions. I am still thinking my core support is somehow jacked as the drivers side fender fits perfectly on my 68 however the passenger side fender is about 1" short from cab to core support and the fender bolt holes to the support are sucked in about 1.5"???? I can shim it and make it look ok but its bugging me that it does not fit as it should? So......, out of curiosity can anyone confirm that all fenders 61-71, sweptline / Ute line, military / civilian, are all the same dimensions?
1968 W100
1967 Plymouth Barracuda
Re: Fender SIze
Absolutely identical. Something is wrong with that specific truck.
Re: Fender SIze
Roger Wilco. Frame looks to be ok. I am going to check the cab alignment tonight and if that is correct I am pretty sure the core support is off. Thanks for helping me narrow this issue down.
1968 W100
