Clutch pedal spring adjustment
- City: Winter Park
It's just that, do you have to remove the dash cluster to get to the spring?or is there a easier way? My pedal on my '63 D100 gets stuck to the floor when depressed.
Re: Clutch pedal spring adjustment
That more usually happens when the clutch master or slave is failing and there is not enough clutch travel to return the pedal. Also make sure the clutch arm return spring has not broken and the rod is properly adjusted. Also possible the pedal shaft needs lubing. Anything up under the dash is way easier thru the gauge opening and they're real easy to pop out. Put 200,000 miles on a 62 W300 since 1987 and have never had to adjust that spring.
- City: Winter Park
Well the truck is new to me, bought last Saturday but he said master and slaves are new....adjusted correctly? I'll have to dig in and see whats what. Picture is "the truck"
Maybe still some air in the system?
- Red383
- City: Fort Loramie
- State: OH
When I got my truck the brake/clutch pedals were pretty stiff. I pulled the shaft that the pedals swing on and cleaned and lubed everything. Made a big difference.
viewtopic.php?f=33&t=41815&p=297636#p297636
Aaron
Aaron
- City: Winter Park
Update...I pulled the cluster only finding I didn't really have to, I loosened the over tightened over center spring, removed the pushrod, which was bent at the bolt end, straightened and welded up the oblong hole, redrilled, reset end play and all is good in the world.
wow must be a zillion miles on that truck! looks great now
