Drivetrain question.
- City: Hawk Springs
- State: WY
Well I have a 318poly on a NP 435 trans up to a NP201 T-case to a Spicer 60 rear end on my 66 W200 and I was wondering how to figure out the gear ratios for this truck and what its top speed would be. Any help would be helpfull.
Re: Drivetrain question.
4th gear is direct and T case is 1 to 1 when in high. Top speed depends on gear ratio in diff plus diameter of tires and some math.
- State: WY
I know it has 32" tires on it ATM IDK the gear ratio but know a good way to find out.
See your build thread for your axle gear ratios.
- State: WY
So the tag says it has 4.10 gears and a 32" tire, would that get me 60mph if I have the motor tuned right?soopernaut wrote:See your build thread for your axle gear ratios.
1965 D200 Crew 5.9L MPFI/A518
Yup, 116 mph downhill, all day long!RoukoSadra wrote:So the tag says it has 4.10 gears and a 32" tire, would that get me 60mph if I have the motor tuned right?soopernaut wrote:See your build thread for your axle gear ratios.
- marklein
- City: Red Deer
Tire has to turn approx 630 turns in a mile, gear ratio of 4.10, means engine will have to turn about 2600 to make 60mph. This is theoretical, it never turns out perfect, but gives a good general idea. If you want it more precise, mark your tire, then mark how many feet it covers in one revolution. Divide that number into a mile, 5280 ft, then multiply that by the diff ratio, you will then be very close.
- State: WY
A lot more complicated than I want it seems
Did you check that there isn't still a little metal tag hanging from a bolt on the front or rear diff? It will say what gears if so. My rear was gone but front was there labeled 4.09 which means the rear is 4.10
- State: WY
mine is labeled the same. 4.09 in front and 4.10 in back.
