Fumes without Smoking
greggeo
Post by greggeo »
I have a Slant 6 runs well.. does not Smoke.. However there is annoying exhaust fumes for cars that follow or even if you sit still after a while. Is this Typical of the older Technology or is there a problem with my Carb adjustment ? Any thoughts are appreciated
thanks,
GG
Bubb
City: Oceanside
Re: Fumes without Smoking
Post by Bubb »
Sounds like your carb is running "rich". One way to tell is to pull your spark plugs and check them out. If they are black, you are too rich. If they are white, too lean. If they are light brown, just right. I still have fumes from my exhaust, but I think I have leaks too.
greggeo
Post by greggeo »
Thank you Bubb I will check that out..
