Vented gas cap
- City: Braselton
- State: GA
Vented gas cap
I have a 69 D100, that has no emission stuff at all on the engine. My gas cap says "pressure vacuum" which I assume means non-vented. I never thought much about it until I drove home one day, and was going to change the fuel filter. When I pulled the fuel line off gas came spraying out like a fire hose. I'm thinking I should have a vented cap on there, am I correct? Thanks
Current rides:
1969 D100 Adventurer- 70-71 grille
1979 Harley FLH rat bike
2006 Harley FLHRSI
1955 Chevy 210 rat rod
1974 Chevy K5 Blazer
1979 Chevy K10
2010 Jeep wrangler JK
2006 Harley FLHRSI
1979 Chevy K10
Re: Vented gas cap
If I'm not mistaken, Pressure/Vacuum means that thescottprop wrote:I have a 69 D100, that has no emission stuff at all on the engine. My gas cap says "pressure vacuum" which I assume means non-vented. I never thought much about it until I drove home one day, and was going to change the fuel filter. When I pulled the fuel line off gas came spraying out like a fire hose. I'm thinking I should have a vented cap on there, am I correct? Thanks
cap is vented to allow for either a pressure or vacuum
situation. Yours might be plugged up though.
- OleRed66
- City: North
- State: UT
Re: Vented gas cap
That's a pretty good seal. Shoot if I take a right turn faster than a crawl, and my tank is over 1/4 full, I get fuel spilling out the cap!
1966 Dodge D100 - Ole Red
1985 Honda Magna - Maggie
Re: Vented gas cap
Me too!
- nfury8
- City: KC, MO
Re: Vented gas cap
The non vented tanks require a vented cap. The caps should be vented one way,
so they don't build a vacuum and collapse the tank (seen it happen!)
A properly working vented cap will still allow pressure to build in the tank.
Why the pressure builds is a different issue. I have been chasing a pressurized tank
issue myself on my 70 Crew. I finally opted to add a vent to the tank, like my 71 has.
Adding the vent is easy, but pulling, cleaning and flushing the tank so you don't
blow yourself up when punching the hole and soldering is another matter!
I have seen vented caps with worn out check valves (which I think are just rubber flaps),
were the rubber had cracked and leaked, allowing fuel to slosh out.
- City: Braselton
- State: GA
Re: Vented gas cap
Well, to be on the safe side, I ordered an NOS vented cap. Thanks
Current rides:
2006 Harley FLHRSI
1979 Chevy K10
2006 Harley FLHRSI
1979 Chevy K10
- Hippy_Dave
- City: Union
- State: WI
Re: Vented gas cap
My local CarQuest had my cap on the shelf - It was like 6 bucks - chrome top looks just like it's supposed to - sorry, forgot the part #
69 D-200
37 Delivery Sedan (in pieces)
92 Dakota - traded for a 2001 Ram 1500
79 Dodge Aspen 2-dr -- didnt have time for it
2010 Charger former squad car = Love it
sweeet
sweeet
- elacruze
- City: Jensen Beach
Re: Vented gas cap
Yup, just bought one myself.Hippy_Dave wrote:My local CarQuest had my cap on the shelf - It was like 6 bucks - chrome top looks just like it's supposed to - sorry, forgot the part #
FWIW vented caps generally allow air in at near 0 vacuum, and vent outward at about 3 psi to prevent overpressure and potential carb overflow/hose failure/leaky seams.
'68 D200 Sweptline Camper Special, 318LA/4 speed
'68 Charger R/T 440/EFI/4spd/D60
My Build thread;
viewtopic.php?f=34&t=23316
My Build thread;
