I've never taken the rear drums off before and am having trouble. I tried using a standard drum puller but just mashed up the threads. I need to get the drums off to pull the axles to switch the pumpkin. Anyone know how to do this?
Stephan
How to remove rear drums '64 D100?
- 2bluesweptlines
- City: Longview, Texas
Stephan
'63 W300 Perkins turbo diesel (for sale)
Re: How to remove rear drums '64 D100?
I recently had to pull the drums on my 64 D100 Town Wagon and used the drum puller in the attached picture; you may be able to find one at a tool rental shop.
Start by removing the castle nut on the axle and then turn the castle nut over and place it back on the axle just until it is flush with the end of the axle. Attach the legs of the puller to the studs and tighten them down and turn the center bolt of the puller until it contacts the axle. Next you grab a 2 pound or heavier sledge hammer and start to hit the end of the dog bone striker on the puller.
If you are lucky after a short while the drum will release with a load pop, that is the reason you need to put the castle nut back on the axle if you do not when it pops it may fly across your garage.
I have heard of many other ways of doing this, but have not personally tried them; an internet search on “tapered axles” will turn up some information.
Good luck
Mike
Good luck
Mike
- 2bluesweptlines
Thanks Mike, I got one off and am not too worried about the other now. I heated it up and ended up using a 4 foot cheater bar and it finally popped off.
Stephan
How did you use the 4 foot bar ? Was it without the puller described by Mike ?2bluesweptlines wrote:Thanks Mike, I got one off and am not too worried about the other now. I heated it up and ended up using a 4 foot cheater bar and it finally popped off.
"Hewy"
1964 D100 318 poly sweptline
1964 D100 225 /6 short utiline
When using the puller like shown in the picture, you don't actually pull the hub off by tightening it. You tighten it as described with a hammer, then hit it on the end with a hard blow and the hub will pop off. Don't be gentle, hit it straight on and firmly. If it doesn't pop off the first or second blow, tighten it more and try again. This is easier on the end of the axle and doesn't spread it as much. You can see that there is a pad on the end of the screw for hitting on. It doesn't look like the puller in the pic has been used much, the areas where you hit on it still look new.
I'm curious about that four foot cheater also.
1969 Adventurer W100
- 2bluesweptlines
I used a very similar puller to the one on the picture, mine just doesn't have the hammer attachment. It looks like that hammer attachment comes off in the one pictured above, then it would be identical to mine. I got a socket that fit the hex end on the puller and attached it to a 1/2" drive breaker bar and put my 4' long floor jack handle on it.
Stephan
