I'm in need of door glass for my 64 D200. (Somebody smashed my window to steal my ignition switch, which I was able to buy at NAPA for $30, Nice) I have a guy here local that thinks he may have a 71 in his yard. Is the door glass the same for all 61-71 Trucks, I haven't been able to see the truck yet. Are most parts interchangable for these years?
Thanks, Dave
64 Door Glass
- Jeffc
Re: 64 Door Glass
Glass will swap, may need to change the bottem metal part but glass is the same
all years 61 to 71...
Not all cab and body parts will swap early to late (or late to early), doors are not a 'swap in' as the
latch changed and cab sheet change to match he latch, door will bolt on the hinges however.....
Fenders will swap, but late fenders will have holes for side marker lights and differant trim
holes.....
Frames change in full size trucks- Wheel base change- in 65 from the 64....
It is best just to ask what your thinking about changing to see what it will
take to swap something out.....
holes.....
- 63d100sixer
- City: Riverside
Re: 64 Door Glass
hey...i have a whole set of glass for you in riverside, CA...not too far from you....PM me your phone number, if you dont get my PM...they are nice, but I used one for bondo mixing since it was a spare.You may have to put your bottom rail on the passsenger side IIRC, since this one is a little rotten....free for the taking....
they are from a 62/63 but I bought the ones in my doors from a 66...
1968 D200 318 727
1972 D100 360 4 speed
1973 d100 318 727
1973 W100 440 727
1968 D200 318 727
1973 d100 318 727
1973 W100 440 727
- City: san bernardino
Re: 64 Door Glass
The glass will interchange. I have a 64 dodge 1/2 ton with fenders from a 66 dodge 2 ton,hood from a 70 dodge front bumper from a 75 dodge,doors from a 67 dodge,wheels from a 1999 ford crown victoria and bed from a 1960 ford pick up. A lot of stuff is interchangeable.
