twin stick transfer case
- bigk
- City: little rock, iowa
i have never had a twin stick transfer case before. i would like to clean up the floor alittle. could i put the case in high and take off the handle and just use the engage disengage handle? then i would only have the one stick poking out of the floor. or is this not the thing to do?
Re: twin stick transfer case
It seems like it would work,if you don't plan on getting yourself into any tight spots. I assume you are not running a pto winch.
- City: abingdon/va
If you would like to keep the twin sticks. You could get a twin stick kit for a np203 or 205 can't remember which one right off. And I can't find my books. It will take some fab work but it will put your twin sticks inline with your tanny shifter. You can also order a shifter boot to seal out the noise. I have looked into this option just haven't gotten far enough in my build.
JJ
