Restore Engine Restore is supposed to fix compression problems with your engine.
So I've been hearing things and reading things and now I want some fellow sweptliners opinions. I don't wish to use this product in my sweptline, but perhaps my Grand Cherokee. Anyway I wanted to know if you guys knew anything about it. Let me know.
Thanks
1966 Dodge D100 - Ole Red
1985 Honda Magna - Maggie
I used it in a '88 gmc that I sold to my cousin in Seattle. You could kill mosquitos with it. I changed the oil in it and let it run for 2 hours and it almost stoped smoking. It would smoke a little on start up but then stop after a bit. Hell, I even used it to tow a '65 300 25 miles with no smoking at all before he came down to get it. Now when I go up for a visit it doesn't even smoke on start up. Oh, by the way, that truck has 242,000 miles on it. I also use it in my daily driver at every oil change and have noticed a difference and the Shadow has 164,000 miles on it and I'll take it anywere. And when I do get the Sweptys on the road I will use it in them too.
R/T '61 D-100 Utiline '62 D-100 SWB
'64 D-200 LWB CSS 1 of 2 known 3/4 ton CSS's '68 A-100 Pick Up (stolen) '72 Challenger '78 "Lil Red Express"
'97 Dakota Club Cab
thanks guys, this actually helps. My Grand Cherokee has 177K on it and I'd like to keep it for a while. I can't tell that it burns any oil, but I thought, why not try it and see if we can't get a little better mileage out of it. I like seeing all the Navy guys here. I'm a civilian employee of the Navy, so I work hard so y'all can. Thanks
i've always wanted to try it the zmax was about to buy some but ended up getting some slick 50 for the wagoneer instead, but only because it was in front of me and i had the money.
we will see, as I just bought a can along with the Wix filters that are going to replace the Fram stuff.
Life should NOT be a journey to the grave with the intention of arriving safely with a well preserved body, but rather to skid in sideways, beer in one hand,cigar in the other, body thoroughly used up, totally worn out and screaming,"what a ride"
I used it on a 94 dodge dakota I had that had 250,000 miles on it and it worked wonders. I just used it in my boat this weekend and got a few more mph than usual out of it. s#$% sounds pretty good to me
69 d100 adventurer 318 four bbl.
727 / 3.55 rear
Massively Over Powered And Respected
Mutilates Other People At Races
JJ wrote:we will see, as I just bought a can along with the Wix filters that are going to replace the Fram stuff.
I've alway's used WIX filters on the RIGS & the FARM. Never used the restore, (going to now, 318's soundin' rough )a while back there was a wonder lube addvertised on TV that's name started with a D (duramax, duralube?) I used this stuff in a 82 cadilac desiel and got 5 mpg better fuel mileage. Went form 30 to 35 mpg
