W100 / W200 Tie Rod End
Stubs68
City: Manhattan
State: MT
Post by Stubs68 »
Ok, I have seen lots of post and replies on tie rod ends but nothing specific to my truck (at least that I ran across).
I have a 1968 W100 with 3500lb Dana 44 axel. I think this is the same axel and steering link as the W200. I need both the right hand and left hand rod ends. Some parts I have found are the MOOG #ES354L / R and a NAPA #269-2023. Have not found enough identifying info yet on either that would confirm fit on my W100. If you have replaced your tie rod ends recently and can send me the part number I would really appreciate it. Thank You :clap
1968 W100
1967 Plymouth Barracuda
Stubs68
City: Manhattan
State: MT
Re: W100 / W200 Tie Rod End
Post by Stubs68 »
Update. I just disassemble the steering center link and both tie rod ends. The driver side is right hand thread and the passenger side is left hand thread. The big surprise however is that the male tie rod end measures 3/4". From the research I have done this is bigger than the standard W100 / W200 that had the 11/16" end? So now I am looking for a 3/4" fine thread tie rod end for a 1968 W100 with SERT upgrade axles. Could possibly be the same as W300?
1968 W100
Can you post some photos of your front axle? I'd like to see
the knuckles and the tie rod in particular.
Stubs68
City: Manhattan
State: MT
Post by Stubs68 »
Dana 44, 3500lb axle with 7" ball. Tie rod is 3/4" fine thread. Not a very good picture but I may be able to get more soon.
1968 W100
Stubs68 wrote:
Sat Mar 13, 2021 4:50 pm
Highly unlikely. The W300 of that era uses a DANA 70 front which has the tie rods & center link running BEHIND the axle.
Stubs68
City: Manhattan
State: MT
Post by Stubs68 »
Success, thanks to the guys at NAPA that spent over an hour today looking through parts catalogs for me. Turns out that the tie rods listed for W100 with large 3500lb axel and 7" ball up to 69 are for the most part discontinued. Found ones that work for my 68 W100 with 3500lb axel listed as a replacement for a 1986 Dodge W250. They are same as my original 1968 W100. Specs are 3/4" 16 thread rod with 1/2" tapered stem. Part number is NAPA Chassis 269-2760 (right) and 61 (left). The bad part is that they are $56 each. The good part is that I actually found them :clap and they are made in the good ole USA. :salut :clap Thanks to those that had suggestions. Maybe this can help others with SERT upgraded W100's or W200's.
1968 W100
MikeM
City: tucson
Post by MikeM »
Good to hear. After reading ur post I went to my spare pile and measured 3 tie rods I have for the large knuckle and sure enough all of them were 3/4 dia as well. Sounds like u have standard 3500lb dana 44 axle tie rods. Let us know if the new ones u ordered do work.
Mike M
Stubs68
City: Manhattan
State: MT
Post by Stubs68 »
Here is an image of the old and new tie rod. New on top, 3/4 inch rod, 16 threads per inch, right hand thread on drivers side, left hand thread on passenger side. Should have time later this week to put everything back together and give an update on fitment.
1968 W100
MikeM
City: tucson
Post by MikeM »
That would be great. Thanks for posting
Stubs68
City: Manhattan
State: MT
Post by Stubs68 »
Tie Rod Ends for W100 / W200 maybe up to 1968
NAPA Precision #269-2760 (R) / 269-2761 (L)
¾” – 16 rod end, ½” – 20 tapered stud, tapered stud diameter top = 0.543, tapered stud diameter bottom = 0.630
From Autowinner.net: http://www.autowinner.net/pages/?show=1 ... ro&Stitle=
Autowinner # MOOG # Raybestas # NAPA # OEM
AW-ES2847RT ES2847RT 401-1449 269-2760 48384167
AW-ES2848LT ES2848LT 401-1450 269-2761 43811468, 4384167, 4384168
1968 W100
Stubs68
City: Manhattan
State: MT
Post by Stubs68 »
Closing out this thread. Tie Rods installed, they fit great and work. See above measurements and part numbers. Again this is for my 1968 W100 with 3500lb axel and 7" ball joint. May fit other trucks. Check you application.
Tie Rod Capture 2.PNG (196.86 KiB) Viewed 1832 times
1968 W100
looking good. thanks for part number info. that big knuckle 44 is a great front end.
