another frame swap question
61shorty
City: Redding
Post by 61shorty »
i searched and i searched......having trouble finding articles on using a mid 70's front clip on earlier trucks.(61-71).... info and pics would be nice.....i was just about to do the aspen swap when i scored a deal on a 75 d100...need to find out which is best.......thanks !!!
Re: another frame swap question
Which is best for what? It depends on what you are building it for. Lowered?
FredM
Post by FredM »
On the home page there is a link to the site in early days
With lots of information and pictures puting a newer front on a sweptline
I can't seem to get there like I used to maybe someone can direct you there
Don't do it like they did on the home page. Under the cab is where you want the splice because the frames are the same width and height. Cut behind the transmission crossmember so you know that the engine mounts and crossmember will be the correct distance from each other. The only problem is that you have to make or modify the front cab mounts. You will also have to make brackets for the radiator support. The rear cab mounts stay in the same place and can be reused.
I don't really have any good pictures of the splice on my frame but Cageman might have some pictures of ones he did.
youngatheart
City: Clearbrook
State: MN
Post by youngatheart »
I just did this swap on my 62 Town Wagon,using front clip from a 75. It went fairly well once I gathered up the courage to make the first cuts! Hopefully it'll all work out,I have the 440/727 sitting in it now. I do have some pics,I'll try and load em up for you,don't know if they're good enough to help you out though. I'm also not sure if the Townie used the same frame as a pickup,I kinda think it is. I spliced mine in the bend part,not under the cab,so I maybe made it harder than it had to be,I don't know. I did away with the trans crossmember for the 4 speed,and moved the next crossmember ahead and bolted it back in for the 727 mount. Hope this helps
61shorty
City: Redding
Post by 61shorty »
thanks for the info !!!!...pics would be awesome if anyone has some.........
